Author Topic: Kx250 power valve questions  (Read 6123 times)
Offline Cabmkr
« on: March 07, 2014, 12:57:19 pm »
Is there supposed to be any forward/backward play (1/4") in the power valve governor lever on an 89 KX250 (you can take it out of the colar on the power valve operating rod with no disassembly)
Cabmkr
« Last Edit: March 07, 2014, 09:41:36 pm by Cabmkr »
Current rides/projects 75 MX125B, 75 TY250B, 75 Carabella Rally 175, 76 TT500 Ice bike, 78 IT400E 79 CB750F , 81 XS650H Street Tracker, 81 YZ250H X2, 93 DS80
Offline Ktm181
Re: Kx250 power valve questions
« Reply #1 on: March 10, 2014, 05:57:18 pm »
not THAT much mate. if I remember right they had bushes, yours are either worn or non existent, if you cant buy bushes you should be able to have some made fairly easily.
Kt.
« Reply #2 on: March 10, 2014, 06:31:01 pm »
im with him....chinaman has been in there..... sumting wong
Offline smed
« Reply #3 on: March 10, 2014, 06:50:32 pm »
There is a set screw/ locating bolt that stops the shaft from moving by the looks,is that missing?
Dumb question but is the 10mm headed nut part# 92015 not loose ?
« Reply #4 on: March 10, 2014, 10:13:04 pm »
Meant to have a look at my 87 but didn't get around to it, I don't recall the bushes but it is definitely too loose.
As Smed says it could be as simple as the lower bolt that holds that arm on being loose or someone may have forced it out in the past and so the arm could be bent.
Offline Cabmkr
« Reply #5 on: March 12, 2014, 08:50:57 pm »
Thanks for the info guys, turns out the small screw/pin in the case cover, that holds it in place was missing the pin part. It wasn't even broken off in the case just missing altogether. This bike has a few other mysteries that I may need some input on if I keep it  :-\
