Author Topic: Husky 82/83 CR250/500 rear suspension dimensions?  (Read 3923 times)
« on: March 06, 2014, 08:39:02 pm »
Hey Guy's,
Just wondering if anyone with an 82 or 83, Husky CR250 or 500 could take a couple of dimensions for me, I'm mounting a pair of ITC rear Ohlins to a '79 KX250A5 and would like get a similar ratio, thanks.
1) Swingarm pivot to rear axle.
2) Swingarm pivot to lower shock bolt.
3) Swingarm pivot to upper shock bolt.
Re: Husky 82/83 CR250/500 rear suspension dimensions?
« Reply #1 on: March 06, 2014, 09:03:07 pm »
82 & 83 are miles different.
« Reply #2 on: March 06, 2014, 09:06:16 pm »
83 & 84 used ITCs
Offline Stevo17
« Reply #3 on: March 10, 2014, 09:08:43 am »
Hi John,
I can measure my 82 up for you but they are different to the 83's with the ITC shocks. The frames are significantly different.  steve
« Reply #4 on: March 10, 2014, 02:02:17 pm »
I can do the WR  ITC but it has the 10.5 inches option fitted
Offline Gippslander
« Reply #5 on: March 10, 2014, 02:23:47 pm »
83 CR250 Husky
measurements from centre to centre of bolt/axle
from swing arm pivot to shortest axle position 525 mm and to longest axle position 560 mm
from swing arm pivot to top shock mount 290 mm
from swing arm pivot to bottom shock mount on swing arm 525 mm (bottom mount is in the centre of the swing arm tube, swing arm is straight)
Shock extended length 465 mm
 8)
