Author Topic: Swingarm bolt seized in engine cases  (Read 16640 times)
Offline SON
Re: Swingarm bolt seized in engine cases
« Reply #30 on: March 10, 2014, 07:21:24 pm »
MIG the biggest possible nut to the pivot bolt and slide hammer them out
Simo63
« Reply #31 on: March 11, 2014, 10:12:41 am »
If you are after heat then forget the Mig .. use an Arc welder as they provide much more heat into the weld.
I've just read this entire thread as I found out I have to do exactly the same to my YZ125G ... bloody swing arm bolt turns but is seized in solid .... will get the rost off today and see how we go  ::)
« Reply #32 on: March 11, 2014, 01:08:39 pm »
Just helped a mate with an xr 100, axle seized in the centre tube.. managed to get it out enough to cut 2" of it then bashed it back and got the wheel out....
Offline kdx Geoff
« Reply #33 on: April 25, 2014, 03:15:02 pm »
Finally out ! Freakin bolt fought me every step of the way.
As the bolt was hollow it was straight forward drilling down the centre.
l tried as l drilled to knock it out thinking with just a thin part of the bolt left it might come out. No
Once l drilled all the way through l used a ground down a hack saw blade to cut through the length of the bolt and free it up but even then it took a fair bit of effort and lube to get what was left out
Took weeks to get this out but other than some minor damage to the spacers from the angle grinder, we all came out of it unscathed, bolt excluded.
Geoff
« Reply #34 on: April 25, 2014, 06:49:08 pm »
great patience my man! next time buy  bike in better knick! ;D :D
Offline mick25
  • Hunter valley NSW
« Reply #35 on: April 25, 2014, 06:54:39 pm »
Well done Geoff  ;) as 80-85 husky said patience is the key some times you need to walk away and leave it for a while and go back for another go , instead of reaching for a bigger hammer  :o
You have passed the patience class Geoff  8)
« Reply #36 on: April 25, 2014, 07:29:56 pm »
Yeap patience is a virtue  :) well done Geoff.
I bet you felt like clicking your heels and tap dancing when you realised the win ;D
Good stuff.
Offline euro bikes
« Reply #37 on: April 26, 2014, 06:45:45 am »
Just been through the same thing with a mates XR400 it was laying around my shed for weeks , had to cut it out as well . Glad to see it leave the shed!!
« Reply #38 on: April 26, 2014, 09:52:34 pm »
Taa Daa!!! battles won.!!  Now some anti-seize on future re assemblies may just prove handy ;) Cheers
