Author Topic: Swingarm bolt seized in engine cases  (Read 16609 times)
Offline kdx Geoff
« on: March 02, 2014, 12:12:02 pm »
Hi,
I've established that this bolt is stuck in the cases, l started trying to get CRC in there and I've hit the hollow bolt hard enough to mushroom the thread end. I've lent on the bolt head end but not used a significant lever in case l damage it or twist it off and make things worse.
There is very little space between the swingarm and the case (taken up by a seal) to try and cut the bolt but access is difficult anyway.
Idea's ?
Geoff
Offline BAHNZY
Re: Swingarm bolt seized in engine cases
« Reply #1 on: March 02, 2014, 12:50:19 pm »
Heat, bucket loads of CRC and a press. No amount of hitting it will loosen it. Strip it to a frame, engine and swing arm and find someone with press and you'll be good.
Rod (BAHNZY) Bahn
Offline kdx Geoff
« Reply #2 on: March 02, 2014, 01:42:59 pm »
Thanks,
I've stript down the frame and l can get an angle grinder in there to cut the bolt but I've always wanted to buy a small press   ;D
Offline Michael Moore
    • Euro Spares
« Reply #3 on: March 02, 2014, 01:52:08 pm »
Buy a big press instead!   ;D
cheers,
Michael
« Reply #4 on: March 02, 2014, 03:00:15 pm »
coca cola sprayed on will work better than CRC if it's seized solid due to rust  ;)
« Last Edit: March 02, 2014, 03:08:54 pm by oldfart »
Offline Tomas
« Reply #5 on: March 02, 2014, 04:05:13 pm »
if the bolt is hollow cut a thread inside and use slide hammer to pull the bolt out also you can set the frame and swing arm on a drill press and drill it out.
when you start bashing it with hammer the bolt will only get thicker and tighter in the hole.
Offline kdx Geoff
« Reply #6 on: March 02, 2014, 04:44:03 pm »
I've been able to get the bolt to turn enough to say its jammed in with corrosion and not fully seized any more.
l need to cut off about 5 mm of the expanded end of the bolt before l push it through with a press. Its not going to tap through with a hammer.
Geoff
Offline Ktm181
« Reply #7 on: March 02, 2014, 05:23:13 pm »
Hey Geoff, OLD FART is right, coke does work and Subaru Upper engine cleaner works even better!  I had a seized one, SOLID in the case, laid on its side and kept squirting upper engine cleaner for a week, in the end didn't even damage the shaft!  Like yours I could get it to turn but no way could I move it towards OUT. Give it a go and soak, at very least will make pressing easier and less damage to the shaft...try and buy that!   Upper engine clean is about $18 odd dollars a can, smells a bit like caustic but is not, even works great on seized nuts/bolts and is great for soaking and cleaning carbs, engine blocks, you name it.
Kt,
« Reply #8 on: March 02, 2014, 05:29:24 pm »
i got a xt500 swinger bolt out by soaking it with wd40 for 2 months before I tried to get it out. when I did try I used a impact socket on the bottom supported by hardwood timber on concrete and a big stepped pice of shaft I had with a 7 pound hammer, one mighty hit and it started moving and when I got it out you could see how the wd40 had penetrated the rust. good luck with getting it out!
Offline Matador107
« Reply #9 on: March 02, 2014, 05:34:45 pm »
Home made peno oil, 50:50 auto trans oil and acetone. If you decide to press it maybe use some timber blocks to reinforce the swing arm along with a mate to help.
Bultaco Metralla, Matador MK 5, Montadero mk2, El Bandido model 18,plus lots of bits and two Honda XR's 250,350.
« Reply #10 on: March 02, 2014, 06:12:43 pm »
Guys when are you going to give up on your magic potions.
Use the product that makes life easy.
Offline Lewis
« Reply #11 on: March 02, 2014, 06:47:31 pm »
Geoff,I've got a press if you need one.
                                           lewis
Offline SON
« Reply #12 on: March 02, 2014, 07:02:27 pm »
Slake well is right use Rost off first it just works
Offline SON
« Reply #13 on: March 02, 2014, 07:06:59 pm »
Tomas is right
Mig a nut to the bolt and pull it out
Not push it through
Added benefit of the Mig is the heat helps crack the tension,
Offline kdx Geoff
« Reply #14 on: March 02, 2014, 07:52:00 pm »
Kt,
Neither of those liquids sound fit for human consumption  ;D
                                           lewis
Thanks Lewis, see you in a week :)
