Author Topic: 84wr husky Carby size  (Read 3047 times)
Offline hampster
« on: March 01, 2014, 12:16:37 pm »
Hi all,
can anybody in Husky land tell me what size carburettor is on a 1984 wr 250 the parts manual says that it is 36 mm I have a 38 mm on mine.??
Thanks Chris.
Re: 84wr husky Carby size
« Reply #1 on: March 01, 2014, 12:24:31 pm »
ive flicked it up onto café husky...should get an answer or 6
Offline HVA61
« Reply #2 on: March 01, 2014, 03:11:29 pm »
38mm Mikuni
450main jet
35 pilot (standard as supplied is 45) "watch it with the 35 pilot can be a bit lean at times"
2.0 slide
needle 6F16
needle jet P8
Air screw 1 and 1/4 turns
ours absolutely flys with that jetting
Offline HVA61
« Reply #3 on: March 01, 2014, 03:13:26 pm »
i forgot to mention , the 38mm is standard on the 84 model 240's and 250's
Offline PEZBerq
  • Brisbane
« Reply #4 on: March 01, 2014, 03:54:27 pm »
Hamster the 36mm is for the 125 only. Parts manual is a bit confusing I agree but re read it and you will see the 36 is only against the 125's.
I run the 470 main with a 35 pilot and it goes very well. Might try a 450 and see if it sprouts wings  ;D
« Last Edit: March 08, 2014, 08:20:14 pm by PEZBerq »
Offline PEZBerq
  • Brisbane
« Reply #5 on: March 01, 2014, 03:57:16 pm »
Should have mentioned I run 3% oil -  32:1 Mixture makes a difference to the jetting.
