Author Topic: 1986/87 KX250 motor stuff [Sold, pending payment]  (Read 3302 times)
« on: February 26, 2014, 09:03:00 pm »
No treasure, but may be useful to someone?
Both engine numbers begin with KX250EE-00xxxx.
Motor on the right has a seized big end.
Motor on the left seems to have a good big end.
Barrel NEEDS to be replated. Power valve missing.
Note the different primary drives, and water pump/PV drive gears.
All sold, pending payment.
In Yass, southern NSW.
Nathan. 04000 23847
« Last Edit: February 27, 2014, 01:27:14 pm by Nathan S »
Re: 1986/87 KX250 motor stuff.
« Reply #1 on: February 26, 2014, 09:23:44 pm »
I wonder if much of it will fit the 88 KX250, incase I need anything for the bikes I have?
« Reply #2 on: February 26, 2014, 09:40:02 pm »
'87 was a one off engine, not much interchanges with anything else.
« Reply #3 on: February 26, 2014, 09:44:31 pm »
Weren't '86 250's a "D" designation?
« Reply #4 on: February 26, 2014, 10:04:36 pm »
Yeah, that would make sense. I second-guessed myself when I saw the two different primary drive gears.
FWIW, it seems that all of the newer KX250 motors (and presumably some older ones) share the same architecture. I would not promise anything, but I'd expect that the crank and gearbox would be interchangeable with the 88 models.
« Reply #5 on: February 27, 2014, 11:57:45 am »
Alloy kick start lever on hold.
