Clubroom
Tech Talk
Coolant for magnesium water pump?
Topic: Coolant for magnesium water pump? (Read 3759 times)
Racer X
Novice
February 21, 2014, 02:18:20 pm »
I'm picking up a 1988 CR 500 tomorrow. Apparently these bikes suffer severe water pump casing corrosion due to being made from Magnesium. What's the best coolant to run?
Paul552
HEAVEN #552
Re: Coolant for magnesium water pump?
February 21, 2014, 03:56:21 pm »
I would go for a devcon based one
On a serious note I use a nulon brand one a concentrate but don't add water.
'77 YZ125D '84 CR250RE '89 CR250RK '84 CR80RE '09 YZ250F
Racer X
Novice
February 21, 2014, 04:39:08 pm »
http://liquidintelligence.com.au/products/motorcycle-super-waterless-coolant
This looks good, no water whatsoever in this stuff.
Paul552
HEAVEN #552
February 21, 2014, 05:04:03 pm »
I reckon that is the go.
On a serious note think of "painting" the internal parts of water pump casing with devcon also.
Just to try to cover the magnesium before it is f$cked
marshallmech
A-Grade
Reply #4 on:
February 21, 2014, 05:56:07 pm »
Always use distilled water if you use water i have always used a Penrite corrosion inhibitor in my 81 125 since it was new but the 81 has alloy housing so it doesn't suffer as bad and use inhibitor only not anti freeze or boil
Andy Viper #70
Honda CR125 RB
Honda CR125RC
Honda CR125RA
Honda CR250RZ
Honda Z50A
CRTAD313
C-Grade
Reply #5 on:
February 27, 2014, 05:35:26 pm »
The later 80's cases were nowhere near as bad as the earlier ones Paul , the 84's are famous for it and are hard to source , unlike yours which are still very available and interchangeable with later years also I believe.
Clubroom
Tech Talk
