Author Topic: Help - CR250 82 / 83  (Read 8197 times)
Offline Digga
« on: February 21, 2014, 11:36:34 am »
I have an 82 CR250 that I am rebuilding to race & have now completley stripped it down to restore.
Have since found that the motor is actually an 83 serial number but the head & barrell appear to be from an 82 model.
Engine # is ME03E-2502491
Head is stamped HF-1 & 1Y2 (maybe? bit hard to read)
Barrell is stamped HF-1 & 1219 (again hard to read the numbers) with 82 stamped on the underside
According to schematics on the web, it looks to be an 82 head & barrell so wondering if this is going to be OK if I rebuild it as is or will there be issues that I need to be aware of & will need to be rectified.
Appreciate any advice please & can send pics if anyone needs to see what I have got, thanks
1977 Yamaha YZ250D, 1977 Yamaha YZ400D, 1980 Yamaha YZ125G
Offline oldyzman
  • 250 two stroke!
Re: Help - CR250 82 / 83
« Reply #1 on: February 21, 2014, 03:20:52 pm »
if its 83 it will have 7 head studs...
Offline Digga
« Reply #2 on: February 21, 2014, 03:28:17 pm »
There are definitely only 6
Offline oldyzman
  • 250 two stroke!
« Reply #3 on: February 21, 2014, 06:04:44 pm »
Maybe 82 then
Offline Digga
« Reply #4 on: February 21, 2014, 10:06:56 pm »
Yes, so it is definietly an 82 barrell/head then, so what I need to know is will it still be OK to use on the 83 motor bottom?
Offline Digga
« Reply #5 on: February 22, 2014, 06:58:14 pm »
Anybody able to clarify this one for me?
82 barrell/head onto an 83 motor? Will it be OK or is it going to self destruct on me???
Offline oldyzman
  • 250 two stroke!
« Reply #6 on: February 22, 2014, 08:18:07 pm »
Well they do take the same piston 81 82 83...
Offline Digga
« Reply #7 on: February 22, 2014, 10:13:07 pm »
OK, well I suppose my concern comes from the Clymer manual where they quote:
Compression ratio
1981 - 7.5:1
1982 - 7.6:1
1983 - 8.4:1
Hence my query as the 82 & 83 cylinders look different in the pics I have seen  ???
Offline oldyzman
  • 250 two stroke!
« Reply #8 on: February 22, 2014, 10:56:09 pm »
Where are you located?
Offline Digga
« Reply #9 on: February 22, 2014, 11:04:06 pm »
Adelaide
Offline oldyzman
  • 250 two stroke!
« Reply #10 on: February 23, 2014, 08:12:24 am »
If you were in sydney, i would offer you to see mine to compare..
Brett
Offline Digga
« Reply #11 on: February 23, 2014, 10:12:20 pm »
Thx Brett, I will just have to wait patiently in case someone else on the forum can help out, cheers
« Reply #12 on: February 24, 2014, 12:41:33 am »
Seems that the crank, rod, piston & base gasket are common to both the 82 & 83 models so I doubt they are too far different.
When the piston is installed just check that it comes level with the top of the cylinder at TDC
If it sits too low or too high then you will have a problem, I doubt this will be the case and this is the only thing that I can foresee that might stuff an engine.
For the most part the cylinder will have changed for minor things, different porting and it seems an extra headstud
Offline Digga
« Reply #13 on: February 24, 2014, 02:34:31 pm »
Thx Geoff
I will get back out into the shed later in the week to check as you suggest. If these parts are all the same (or near enough to), then  how did they bump the compression ratio up so high between the 82 & 83 models? Is not important really but just curious?
Offline oldyzman
  • 250 two stroke!
« Reply #14 on: February 26, 2014, 07:19:14 pm »
FYI
The height from base to head is 134mm on My 83 cr250RD.
