Author Topic: Preston Petty Sealed Beam  (Read 4542 times)
Tony T
« on: February 17, 2014, 08:18:35 pm »
Would anyone know of a reasonably priced replacement for the 6 volt sealed beam in a Preston Petty headlight?
It's about 4" in diameter but I'm happy to cut, shut and modify as needed.
Ta.  :)
Offline Canam370
Re: Preston Petty Sealed Beam
« Reply #1 on: February 17, 2014, 08:26:11 pm »
I've found a 12v replacement but not a 6v. Improve your electrics Tony!
Offline Rookie#1
  • JUST SHUDDUP AND RIDE IT!!!
« Reply #2 on: February 17, 2014, 08:51:27 pm »
Nope, but did you know a lid from a tin of "s26 gold" baby formula fits perfectly over the light housing as a cover to protect your lamp??!!! Or even just to finish off the item if you don't have a light fitted. Just a lil fun fact  ;D ;)
Tony T
« Reply #3 on: February 17, 2014, 09:11:37 pm »
I thought you'd be off formula by now, Rookie......  ;D ;D ;D
It's got a sealed beam in it, so it looks the part, but it's blown.
12 volts, Paul? I heard that they make bikes with 12 volts electrics these days, but I didn't believe it.........  :-\
Offline matcho mick
    • Moto Tumbi
« Reply #4 on: February 17, 2014, 10:38:33 pm »
Tony,i thought they (PP) were all 12v,all of mine have been,been thinking to check the fancier ride on mowers??,(cheapies have tailite globes :o), :P
Offline b490
« Reply #5 on: February 17, 2014, 11:31:41 pm »
 UFO make a universal  105mm ( approx. 4") plastic lens unit  P/N ME08076.
  Not sealed beam so you could   fit suitable  6v globe.
http://www.ufoplast.com/en/product-details/mx-enduro/vintage-plastics/ME08076
http://www.enduroklassiker.at/en/electric-parts-and-ignition-parts/2954-scheinwerfereinsatz.html
  Regards ,
                 Steve
« Last Edit: February 17, 2014, 11:47:53 pm by b490 »
Offline grouty
« Reply #6 on: February 18, 2014, 01:22:58 am »
I spoke to Paul at Hodaka a few years ago regarding this as they handle the PP products now. It seems there are no 6 volt sealed units. The 12 volt lamp is similar / same as some small tractor / lawn tractor units. So I guess if you have the time (inclination) then start trawling the lawn tractor sites.
I gave up as I found a NOS front light set-up for my Husky.
Thumpers Rule !
Tony T
« Reply #7 on: February 18, 2014, 07:39:02 am »
Thanks fellas.
Yes, the one I have would be 12V, but the bike is 6V so that's what I'm after.
Good idea about lawn tractors. I shall investigate.  :)
« Reply #8 on: February 18, 2014, 02:25:19 pm »
those back up lighting systems you see in stores etc could be 6 volt but would only be a single beam and of floodlight type spead, same goes for ride on mowers
Tony T
« Reply #9 on: February 18, 2014, 03:05:59 pm »
Thanks Matt.
I'm going 12V now. Just works out easier.
What sort of light it is doesn't matter. Hopefully, it will never have to be used to actually see where I'm going.  ;D
« Reply #10 on: February 18, 2014, 03:15:46 pm »
ok then but use a 12v AC voltage regulator then,they can be sorced from xl600 maybe xl250/350 as well
Tony T
« Reply #11 on: February 18, 2014, 03:29:12 pm »
Already got one.
Tony T
« Reply #12 on: February 19, 2014, 08:18:46 pm »
Being impatient (and poor), I ended up cutting the back out of the original sealed beam and fitted a 60/55 globe and holder.
Top it off with  a 12V reg off an old 610 Husky and a switch block from an XT550 and I've now got lights!
And good lights too!  8)
It did take while to get working though, cos the brand new fuse holder had an open circuit inside the moulded bit!  >:(
Thanks again for all the advice. I didn't follow any of it.........  ::)
