Author Topic: is this an evo bike or pre 90  (Read 4695 times)
Offline oldyzman
  • 250 two stroke!
Re: is this an evo bike or pre 90
« Reply #1 on: February 15, 2014, 02:29:43 pm »
Drum Brakes, Air cooled, non Linkage suspension = Evo I believe...
Brett
Offline JAP 454
  • See Ya at the Skids
« Reply #2 on: February 15, 2014, 02:58:24 pm »
It'll do me for EVO
Foss
Offline yamaico
« Reply #3 on: February 19, 2014, 07:45:11 am »
You should buy that Jim - you'll only need to buy three #4's for the number plates ;D
« Reply #4 on: February 19, 2014, 09:35:07 am »
If you think about it, that's an early prototype of the SexMax...
Offline KTM47
« Reply #5 on: February 19, 2014, 10:43:43 am »
Yes and just as illegal.  Is there any Evo legal bikes that used the Rotax's motor.  The 84 KTM had single shock rear end and the Can AM Sonic had a disc brake.  Unless the assembler of this bike was/is a manufacturer it is not OEM.
MAICOS RULE DESPITE THE FOOLS
Offline Husky500evo
« Reply #6 on: February 19, 2014, 11:20:31 am »
[quote
[/quote
Why would this bike not be Evo class legal ? An '82 Can Am Sonic came from the factory with a 500cc  Rotax motor, front and rear drum brakes and twin shocks.
Offline KTM47
« Reply #7 on: February 19, 2014, 12:11:06 pm »
[quote
[/quote
My apology the only Can Am Sonic I have seen had a front disc brake.
Offline KTM47
« Reply #8 on: February 19, 2014, 01:36:23 pm »
So the Can Am Sonic is EVO legal.  The only one I have seen has a disc brake, so not standard.
Courtesy of CannedHam.com
Specifications:
Displacement                             500 CC
Bore and stroke                         89 mm x 79mm
Engine Cooling                           Air
Spark Plug                                   NGK D8es-L
Carburetor                         36mm Mikuni
Transmission:                             5-Speed
Steering Rake                             29.4 Degrees
(Castor):
Wheelbase:                        58.5 inches
Ground Clearance:                   11.0 inches
Weight (dry):                              278 lbs.
Fuel Tank Capacity:                 2.8 Gallons
Forks:                                   42mm Marazocchi
Fork Travel:                       11.8 inches
Shocks:                                Ohlins Dual Shocks
Shock Travel:                              12.9 inches
Front Wheel:                     21 inches
Rear Wheel:                       18 inches
Brakes                                  Drum/Drum
Cost When New:              $2,999
« Reply #9 on: February 19, 2014, 05:33:47 pm »
if you reed the add 200 of these were made by a manufacturer in the uk. he sorced parts from other bike manufacturers and built his own.it failed to sell so it is oem as it left the workshop/factory in the uk.
Offline euro bikes
« Reply #10 on: February 19, 2014, 06:14:22 pm »
There was a SONIC raced here in QLD  it was stock with drum brakes.
Offline DR500
