Author Topic: 84 kx250  (Read 1211 times)
Offline Spanish Armada
84 kx250
« on: February 12, 2014, 08:23:38 pm »
Kx250 chassis in very good cond has had small bracket welded on for rear  slave cyl and reservoir (as this bike was raced believe it on bitumen) ::).Frame comes with swing arm /shocker (will need rebiuld) shaft ok. Original bolts/linkage/complete air box (rubber is ok no cracks or worn thru from spring)Fuel tank in very very good order and tap /Triples with forks but rusty sliders/Radiaters but bent/Side covers original and ok (not cracked) would cleanup/ and Rear guard also not cracked and would cleanup (with a bit of sanding and polishing.$500 cash on pickup and u arrange freight and packaging. send me a  pm here and will get back to u when u supply phone no .cheers
