Author Topic: Removal of 73 CR250M clutch arm query.  (Read 2060 times)
Offline Adam
« on: February 08, 2014, 06:04:27 pm »
Probably a dumb question but is there a trick to removing the clutch actuating arm on a 73 CR250M once you've removed the retaining screw?
Mine will pull up about 30mm from its original position, but will not budge any further no matter what direction I turn the arm.
Thought I'd better check before applying some force to it.
I need to remove it as its been modified where it retains the clutch cable and I have a new one to fit,
Parts fiche on CMSNL doesn't show anything else that would restrict its removal once the retaining screw is out
Offline Adam
Re: Removal of 73 CR250M clutch arm query.
« Reply #1 on: February 08, 2014, 06:20:24 pm »
Please disregard this query
Wasn't trying hard enough.
Sorted
