Author Topic: IT250j-H -465- 490k-L clutch side cover  (Read 4271 times)
Offline smartie
« on: February 07, 2014, 10:34:48 pm »
Hi, dose anyone have a useable clutch side cover of an IT250j-h 465-490 K-L that is hiding under a bench somewhere
that needs a good home.
thanks smartie.
« Last Edit: February 08, 2014, 02:45:17 pm by smartie »
Re: IT250j-H -465- 490k-L clutch side cover
« Reply #1 on: February 08, 2014, 12:27:03 pm »
 :-\ good luck I have been trying for one for a while now and yes the apprentice asks me everytime I see him  ::) have ya found 1 yet :P
Offline 74yza
« Reply #2 on: February 08, 2014, 12:52:00 pm »
I am parting out a IT465 and the cover is available. What if any are the issues with them ?  I can check on mine tomorrow if I know what to look for. Currently all parts are available   Tom
Looking for 74 75 YZ 250/360  WORKS parts  Anything !
Offline Cabmkr
« Reply #3 on: February 08, 2014, 01:51:54 pm »
Why are you looking for one? Is it worn, gouged or what. If the Kickstart shaft area is worn, a bronze bushing can be installed. I have fixed gouged cases with JB weld and repainted
Cabmkr
Current rides/projects 75 MX125B, 75 TY250B, 75 Carabella Rally 175, 76 TT500 Ice bike, 78 IT400E 79 CB750F , 81 XS650H Street Tracker, 81 YZ250H X2, 93 DS80
Offline smartie
« Reply #4 on: February 08, 2014, 02:38:55 pm »
i had a bush made in the kick starter side of the casing and it might be out of centre , im having trouble with the rear wheel locking when you push the bike and every now and then,and you can feel it starting to lock while you kick it over some times. i have had the complete engine apart 6 times it all loks good inside.
smartie.
« Last Edit: February 08, 2014, 02:45:33 pm by smartie »
Offline FourstrokeForever
  • AKA Mark H #35 VCM
« Reply #5 on: February 09, 2014, 10:42:17 am »
Sounds like a clutch problem to me. Have you checked to see that the clutch basket isn't badly worn. If the tangs on the basket are serrated, that can cause the clutch plates to lock.
Offline Cabmkr
« Reply #6 on: February 09, 2014, 10:52:58 am »
even if the hole in the cover is out of round it could have been referenced off of the seal side of the cover for centre. If you are meaning the kicker gets tight sometimes kicking it through, mine did the same thing, check the bushing area and the plastic spacer and spring, one of them may be binding Also my cover had a U shaped grove on the kicker hole which I ground down back to flat(more or less)
Chris
« Reply #7 on: February 09, 2014, 08:15:35 pm »
The kickstart mechanism is not going to make the bike hard to push
Offline Cabmkr
« Reply #8 on: February 09, 2014, 09:03:32 pm »
A worn or binding kicker can make it kick strange through the travel and be inconsistent. I am not under standing the "pushing" hard its in neutral or not. I agree that a worn clutch basket (or warped) plates could cause it to drag but in my experience that is quite consistent.
   Smartie, any photos might help us figure it out.
A couple things to try, check the chain, it could be too tight, rear wheel bearings, and pull the chain off and check the output shaft, a bearings with a broken cage could have the balls binding up.
Also loosen the clutch cover, and see if that makes a difference in any binding.
Cabmkr
Offline smartie
« Reply #9 on: February 11, 2014, 09:15:01 pm »
i will be out in the shed tomorrow afternoon and look at it then
smartie.
Offline smartie
« Reply #10 on: March 14, 2014, 07:17:17 pm »
all fixed,the bike is back on the road ,another new gearbox fixed it all.
smartie.
