Author Topic: Axel Nuts  (Read 8313 times)
Offline kenny5000
Axel Nuts
« on: February 07, 2014, 01:51:58 pm »
I am in need of at least one but preferably two rear axel nuts to suit a 75 Husky. Im guessing they are an unusual size as I cant find a nut that fits??? Maybe M15 which I believe is no longer made :-\ :-\
Offline Paul552
  • HEAVEN #552
Re: Axel Nuts
« Reply #1 on: February 07, 2014, 03:26:30 pm »
What pitch?
Offline kenny5000
Re: Axel Nuts
« Reply #2 on: February 07, 2014, 04:26:17 pm »
Looks to be about 1mm
Offline kenny5000
Re: Axel Nuts
« Reply #3 on: February 07, 2014, 08:48:41 pm »
I think they are M15x1.5, found some overseas but are expensive and would rather get them from Oz if I can!
Re: Axel Nuts
« Reply #4 on: February 07, 2014, 09:15:25 pm »
Psst Kenny,,, Axel nuts be my grandsons (Axel) knackers,   Axle nuts are the threaded thingos that stop your axle and therefore your wheels coming adrift at somewhat inopportune moments, creating vast amounts of pain, suffering and later hmm shit stirring ;) Cheers Tim754
PS your local nut and bolt supply should have lovely fresh castellated  ones in stock, for about $4.00 each, or $15.00 for stainless steel. :)
« Last Edit: February 07, 2014, 09:19:59 pm by Tim754 »
Offline kenny5000
Re: Axel Nuts
« Reply #5 on: February 08, 2014, 04:56:30 am »
Yes I saw the error in my spelling as soon as I posted but was feeling a little to lazy to fix it!!
I have been to my friendly nut and bolt supplier who informed me that M15 is no longer made.... :-\
Offline Paul552
  • HEAVEN #552
Re: Axel Nuts
« Reply #6 on: February 08, 2014, 08:40:38 am »
Not correct.
Where are you located?
I use
Nepean bolt master penrith
Lee brothers north parramatta
« Last Edit: February 08, 2014, 08:43:01 am by Paul552 »
Offline kenny5000
Re: Axel Nuts
« Reply #7 on: February 08, 2014, 08:54:49 am »
I'm in Melb, I'll check out a few other suppliers.
Offline pancho
Re: Axel Nuts
« Reply #8 on: February 08, 2014, 10:19:57 am »
Yes, I thought you were talking about an African American nut in the movies
Offline kenny5000
Re: Axel Nuts
« Reply #9 on: February 13, 2014, 05:53:29 pm »
After using a pitch gauge I found that they are M15 x 1.25 and can't locate them at any nut and bolt shop! Anyone got a couple of husky rear wheel nuts they would like to sell??
Re: Axel Nuts
« Reply #10 on: February 13, 2014, 06:18:32 pm »
Try  http://www.partsyahoo.com/NUT-M15X1-25-p/125-382.htm    yeah from the USA but sounds like the ones. cheers
Or perhaps this company  http://www.boltdepot.com/Metric_nuts.aspx?nv=rel
Or maybe this Aussie business that I have had success with over the years
Bendigo
Bolts & Fasteners Pty Ltd
158 Lyttleton Tce Bendigo 3550
Phone 03 54414122
Fax 03 54416144
PO Box 451 Bendigo 3552
« Last Edit: February 13, 2014, 06:31:40 pm by Tim754 »
Offline kenny5000
Re: Axle Nuts
« Reply #11 on: February 13, 2014, 06:50:09 pm »
I was in bendigo yesterday, tried them because I was there, no luck! HVA factory has them but at €19 a pop I'm sure I can find an alternative!! I'll try the others you suggested!
Offline Canam370
Re: Axel Nuts
« Reply #12 on: February 13, 2014, 07:00:35 pm »
Just a little heresy - cut a new more common thread onto the axle - be cheaper than 19lbs (sorry, don't have a pound key).
Offline pmc57
Re: Axel Nuts
« Reply #13 on: February 13, 2014, 08:41:52 pm »
How common are these nuts? If you're keen to source and see a need for them in the wider market go to any engineering shop with a CNC lathe and have them make 20 or so then get them zinc plated, average out the cost plus a bit for the effort and you're in business.
Alternatively ask around your mates for someone who has a lathe in their shed and ask them to make one. Then get it zinc plated.
Re: Axel Nuts
« Reply #14 on: February 13, 2014, 09:24:42 pm »
Get a machine shop to whip you up some new axles with a more conventional thread size
