Author Topic: 1976 CR 125  (Read 4587 times)
TM BILL
1976 CR 125
« on: February 07, 2014, 08:20:50 am »
Got a 1976 CR 125 , im not generally a Honda person but they are a cool looking thing IMHO .
For not a Honda person they are growing in the shed  :) 79 CR 250 , 84 CR 250, 76 CR 125 , 79 XR 200
Want to freshen up the motor as it has not been run for a few years 10+
Can anyone tell me good sources for a rod kit , piston kit , gasket set , and clutch plates  for the 125
Thanks Bill :)
what's the best aftermarket chamber for this model ?
« Last Edit: February 07, 2014, 08:25:12 am by TM bill »
Offline gdr
Re: 1976 CR 125
« Reply #1 on: February 07, 2014, 08:25:03 am »
try pro-x
HONDA THE POWER OF DREAMS
Re: 1976 CR 125
« Reply #2 on: February 07, 2014, 10:49:23 am »
Rod kits are hard to find, it's easier (but more expensive) to get a later model one but you have to get the crank webs drilled bigger for the new pin. Piston kits are easy, Woosner do them. Gasket sets from evilbay USA......what are you doing farking with shit?.....do us all a favour and dump it in the lake mate. ;D Check the engine mount holes, they are probably twice the size there suppose to be.
TM BILL
Re: 1976 CR 125
« Reply #3 on: February 07, 2014, 10:53:37 am »
Where do you think I found it   ;D
Thanks for the advise though , I will split the crank and have a measure up first  :)
Offline suzuki27
Re: 1976 CR 125
« Reply #4 on: February 07, 2014, 11:57:30 am »
I've got a vague memory about the 1980 CR125 rod being close.
TM BILL
Re: 1976 CR 125
« Reply #5 on: February 07, 2014, 12:15:07 pm »
Thanks Bill
Offline bazza
Re: 1976 CR 125
« Reply #6 on: February 07, 2014, 01:03:45 pm »
 Bill your im not buying any more bikes resolution is going well :D :D :D :D :D
Got offered 76 Honda CR250 but at the price with the work to do will may be import one
Embrace patina
TM BILL
Re: 1976 CR 125
« Reply #7 on: February 07, 2014, 01:34:03 pm »
Mike im sticking to my no more Buying bikes  ;)however horse trading and accepting orphans into the fold dont count  ;D
Offline Bamford#69
Re: 1976 CR 125
« Reply #8 on: February 07, 2014, 02:19:19 pm »
Hi,
 Serco Brisbane have done all my 74 CR 125  cranks over the past 18 years , and use Hot Rods #8162 (CR 125  81-84) (Suz RM125 84- 86) they do require initial modification to crank (bigger pin if I remember right) CR125 73-78 genuine  haven't been available for quite some time,
go online for gasket set , seal set ,there is a odd size  Honda crank seal right side (inside) the bearings are available at any good bearing shop .
the fast guys up this end of town are using GMC pipes (I'm not yet)
Re: 1976 CR 125
« Reply #9 on: February 07, 2014, 03:00:53 pm »
There's a very strong Yamaha rod which does the job & won't break when the bike revs to 14,000 rpm when the rear wheel comes off the ground. It works out quite expensive though, but no crank mods needed. I usually just use the '84 rod & bore the webs to take the bigger pin.
Offline Ted
Re: 1976 CR 125
« Reply #10 on: February 07, 2014, 04:09:13 pm »
You beat me to it ;D
WTF are you doing Bill. Use it to start a hungy or something.
81 YZ 465 H   77 RM 125 B
