Author Topic: Front Brake Levers for Drum  (Read 2829 times)
Offline ninjamk
« on: February 06, 2014, 03:07:23 pm »
Does anyone know of any front brake levers and perches that give a longer cable pull over a OEM TS or TM250 set?  As of right now if I adjust the front brake to get good stopping power, the wheel drags.  If I get rid of the drag, the bike doesnt want to stop.  Suggestions?
Thanks!
Bikes: 1972 TS/TM250, 2007 KLX300, 2016 GSX-S1000
Re: Front Brake Levers for Drum
« Reply #1 on: February 06, 2014, 03:15:14 pm »
Hi ninjamk,
Sounds like you have a stretched outer cable that is acting like a spring being compressed when you apply lever pressure.
Also your shoe friction surface may not be running concentric to your drum.
Scour your brake shoe surface, reassemble, LIGHTLY apply your brake while wheel is rotating. Check for the witness of shinny high spots. Don't over apply. Or you will flex the shoe and create false witness.
If it shows consistent even witness all over your linings,,,,than outer cable stretch is most likely your problem.
Good luck.
« Last Edit: February 06, 2014, 07:05:52 pm by Mick D »
« Reply #2 on: February 06, 2014, 03:18:11 pm »
It is important not to accidentally stretch your outer cable by mishandling during removal or replacement.
NEVER pull or yank on it to get it out of perch adjuster whilst inner nipple end is still attached to the lever.
Offline ninjamk
« Reply #3 on: February 06, 2014, 04:14:29 pm »
Thanks Mick, I will take a look at the shoes.  The cable is pretty new, only has about an hour on it, guess that could still the the issue.  What if the wear is uneven, new shoes?
« Reply #4 on: February 06, 2014, 04:41:51 pm »
Cables are sort of like everything else, you sort of get what you pay for. Some of the dearer ones are very good these days. OEM Suzuki is not too bad though.
Shoes are cheap.
A full healthy lining immediately improves the outcome.
« Last Edit: February 06, 2014, 07:04:54 pm by Mick D »
Offline Ted
« Reply #5 on: February 06, 2014, 05:03:29 pm »
Cutting edge techo....Micky ;D
81 YZ 465 H   77 RM 125 B
« Reply #6 on: February 06, 2014, 05:14:43 pm »
I probably should start drinking again hey ;D
Offline Ted
« Reply #7 on: February 06, 2014, 05:45:41 pm »
I wouldn't stop at alcohol 8)
