Author Topic: rear shocks do they need to be parrallel  (Read 2507 times)
« on: February 01, 2014, 06:25:17 pm »
my long tracker swing arm shock mounts are 15mm wider than the mounts on the frame.so the shocks are not parallel.
will the shocks work like this or do I have to mount the shocks on the outside of the frame to make them parallel.
jim
Offline mick25
  • Hunter valley NSW
Re: rear shocks do they need to be parrallel
« Reply #1 on: February 01, 2014, 06:41:58 pm »
maybe not husky shocks are way off being straight they are more than 15mm.
 they may wear internally on one side of the shocks ???
Off road buggies have there shocks on huge angles.
« Last Edit: February 01, 2014, 06:50:17 pm by mick25 »
« Reply #2 on: February 01, 2014, 07:11:04 pm »
No they don't need to be parallel but will need spherical bearings in the shock eyes at each end ala Husky. As the shocks compress the angle from parallel will increase..
Offline mick25
  • Hunter valley NSW
« Reply #3 on: February 01, 2014, 07:23:24 pm »
I have a set of husky ohlins at my place at the mow , thanks jonny now I realise why they have spherical bearings ;)
you learn something new every day :)
Offline KTM47
« Reply #4 on: February 02, 2014, 01:09:54 pm »
As John said they don't have to be.  An easy way to see if everything is working OK.  Mount them without the springs on and see if they go through their travel without any restriction.
MAICOS RULE DESPITE THE FOOLS
« Reply #5 on: February 02, 2014, 02:10:56 pm »
so I need to put  spherical bearings in the shocks
any one could post a pic
jim
Offline David Lahey
« Reply #6 on: February 02, 2014, 03:23:21 pm »
It depends on shockie length and shockie shaft travel. Husky twinshocks are a good example of a design that definitely needs spherical bearings, while the Cota 172 trials bike is also considerably narrower at the top mounts, but has no problems using just flex in the bushings.
Whatever you use, do make sure that the mounting pivot axes are perpendicular to the centre lines of the shocks when the shocks are at half travel (to minimise the side loading on the mounts)
« Last Edit: February 02, 2014, 03:28:16 pm by feetupfun »
previous pseudonym feetupfun
