Author Topic: I Need help with my Maico- should I convert single to twin shock?  (Read 3375 times)
Offline crabman
Hi Gents
I am looking for some advice. I have a duplicate Maico Alpha 1 single shock 250 (completely restored). I have a part restored Maico 440 frame without a complete motor ( do have cases, barrel, head). I have considered using the complete 250 single shock  bike as a donor bilke and converting it into  a twin shock Maico 250cc.
Obviously the motor and frame will not match, The motor is from an 1982 single shocker, the frame probably late 70' S.
Any suggestions ?
Alternatively will the 440 barrel slip onto the block of the 250 ? Do the motor swop with the 440 barrel, head and pipe ?
Once again any suggestions ?
Many thanks
Gavin w   :)
 Report to moderator    196.35.158.178
Old and slow - and happy
Offline Husky500evo
Re: I Need help with my Maico- should I convert single to twin shock?
« Reply #1 on: June 13, 2008, 08:12:40 am »
The '81 & '82 motors have a different stud spacing where the cylinder bolts to the cases , compared to the earlier motors . But an '81/2 490 cylinder will bolt onto '81/2 250 cases . They also changed the stud spacing again in '83 for the primary gear drive motors . I think Wulfsport in the UK sell a frame kit to convert '82 single shock frames back to the '81 twin shock setup.
« Last Edit: June 13, 2008, 12:46:19 pm by Husky500evo »
Offline paul
« Reply #2 on: June 13, 2008, 08:39:04 am »
find a 78/79  frame and do the franken bike thing ,the later engine bolts straight in is the 82 250 a reed engine
« Last Edit: June 13, 2008, 08:58:52 am by paul »
