Author Topic: 1970 yz / dt  (Read 5745 times)
Offline Sammundo
1970 yz / dt
« on: January 28, 2014, 12:29:38 am »
Hi. Can someone please tell if the frame of the dt and yz are the same from 1974? Im building up a yz 125 from parts but am yet to find a good frame. I have however found a dt frame of the same year about 50km away going cheap. While i would like the right frame eventually i would like to start putting it together so thought this might be a quick fix. Also are there any other parts that are interchangeable without affecting the power or handling?
Re: 1970 yz / dt
« Reply #1 on: January 28, 2014, 12:43:37 am »
not by a long shot . sorry
Offline r4brightred
Re: 1970 yz / dt
« Reply #2 on: January 28, 2014, 06:36:26 am »
I recommend you try and find a MX125a/b or MX175a/b frame. Weld on the tabs for the strap tank and your done. Good luck.
Offline vandy010
  • #789 MX125a BMCC Brisbane
Re: 1970 yz / dt
« Reply #3 on: January 28, 2014, 08:03:55 am »
this is the frame you don't want
but any dt100/125/175 that looks like this will do the trick ;)
I've been racing an MX125a for years and believe the frame differences between the DT/MX/YZ are so small its not an issue.
obviously all the DT rego/lighting brackets etc will need to be ground off and possibly a few other smaller brackets welded on but
the DT's are a great donor bike for the MX/YZ125's
the DT100 frames have slightly different rear engine mount (width) brackets
in the shed here I have the DT100a, DT125c and my little MX125a
go for it!
"flat bickie"
Re: 1970 yz / dt
« Reply #6 on: March 19, 2014, 02:24:34 pm »
Ill sell you a complete YZ125a
