Author Topic: Junk.  (Read 7699 times)
Junk.
« on: January 20, 2014, 08:56:49 pm »
Sorry for linking to Scumtree ad, but it's my most reliable way of getting photos up ATM:
http://www.gumtree.com.au/s-ad/yass/parts/assorted-vmx-parts-mx250-ty175-dt1-xt250-etc-/1036655598
Really, I'm only advertising it so I don't feel guilty if/when I throw it all away... If someone turns up and takes the lot, they can have it for a six pack.
Nathan.
04000 23847
Re: Junk.
« Reply #1 on: January 21, 2014, 03:56:37 am »
ill take the xt250 s/cam ignition system thanks
« Last Edit: January 21, 2014, 10:19:43 pm by TT5 Matt »
Re: Junk.
« Reply #2 on: January 21, 2014, 10:20:56 pm »
Too easy Matt. PM me your address.
Offline Alisdair
Re: Junk.
« Reply #3 on: January 22, 2014, 12:06:31 am »
Really interested in the
Clutch basket from early-mid 80s YZ250
Can you please upload some pictures of it here if possible,
It would be greatly appreciated
Al
« Last Edit: January 22, 2014, 12:14:06 am by Alisdair »
Re: Junk.
« Reply #4 on: January 22, 2014, 08:46:26 pm »
I'm having trouble getting photos to upload.
Can SMS them to you if you PM me your phone number.
Scrappy is coming on Tuesday. Anything not spoken for then, will be leaving with him.
Offline crossedup2
  • Never enough shed time.....
Re: Junk.
« Reply #5 on: January 22, 2014, 10:27:56 pm »
Nathan
I'll take the internal rotors (125 and 250), MX250 head and AT1 seat.
Peter B
Re: Junk.
« Reply #6 on: January 22, 2014, 11:51:28 pm »
No problemo Pedro.
Re: Junk.
« Reply #7 on: January 24, 2014, 06:06:09 pm »
Sold:
DT1 oil tank & head gasket.
Spoken for/on hold:
XT ignition.
MX head.
Flywheels.
AT1 seat base.
Re: Junk.
« Reply #8 on: January 27, 2014, 06:06:11 pm »
Scrappy has been put off until Thursday.
Also discovered a KDX175/KLX250 front hub with speedo drive.
DT1 (I think) flywheel.
AT1 bare airbox.
Big pile of used spokes & nipples. About 150 spokes, roughly.
« Last Edit: January 29, 2014, 07:43:16 am by Nathan S »
Re: Junk.
« Reply #9 on: January 28, 2014, 09:21:07 pm »
More:
Top row: 90s KTM, 80s YZ (obviously broken), generic oval plate modified to sit under a side-pipe, 89 KX, 89 KX modified for RWU forks.
Middle row: 3x home made front plates, mid-80s CR, 89 RM125, generic green ovals, 90s CR.
$5 each or take the lot for $10...
Bars are both straight.
The top ones are ATV/Pastrana bend that I don't like,
the bottom pair have been shortened by about 10mm on each side - turns out that I'm fussy about handlebars...
$10 each set, $15 for both.
« Last Edit: January 29, 2014, 10:35:16 am by Nathan S »
Offline Paul552
  • HEAVEN #552
Re: Junk.
« Reply #10 on: January 28, 2014, 09:28:10 pm »
Nathan is that a flash red cr plate? 84?
If so mate I will take it.
Pm sent
« Last Edit: January 28, 2014, 09:58:52 pm by Paul552 »
Re: Junk.
« Reply #11 on: January 28, 2014, 09:56:08 pm »
PM sent Nathan,
I wouldn't mind the spokes and nipples, handlebars and the KLX250 front hub if it has an intact backing plate?
Re: Junk.
« Reply #12 on: January 29, 2014, 07:44:35 am »
KL250 piston sold.
Re: Junk.
« Reply #13 on: January 29, 2014, 09:00:59 am »
Hey Nathan, would you have a 1W1 clutch hub?.....better still an IT175J hub?....apparently you can drill the 1W1 basket off the gear and bolt it to the 1T175J which seems to be very hard to find. Need it for a job I'm doing.
TM BILL
Re: Junk.
« Reply #14 on: January 29, 2014, 09:17:06 am »
Joan if a 1w1 basket will work what about mono shock DT 175 ?
