Marketplace
Wanted
tm 125 suzuki rear hub.
Topic: tm 125 suzuki rear hub. (Read 2065 times)
Nipper
B-Grade
January 20, 2014, 01:14:21 pm »
looking for a tm 125 Suzuki rear hub, or similar to suit.
TM BILL
Re: tm 125 suzuki rear hub.
January 20, 2014, 01:17:11 pm »
Can do
Do you want the original Cush drive hub TM 125 / TS 125 or the solid hub RL250 , RM 125 S , A , B ?
Freakshow
Superstar
Adelaide, SA - looking for a "YZA" tank
January 20, 2014, 01:33:24 pm »
id have the ts or tm250 wheel well the hub and spokes but may be a steel rim...................
74 Yamaha flattracker's
70 Jawa 2 valve speedway's
For sale - PRE 75 Yamaha MX stuff, frame, motors and parts also some YAM DT1,2,A and Suzi TS bikes and stuff
Nipper
B-Grade
January 20, 2014, 01:54:53 pm »
Currently have the cush drive from a ts 125, this was bolted through the hub to make it a "direct Drive". Problem is the cush drive hub has most of the lugs broken off. So I am actually after the cush drive hub. But I will take whatever fits and works as this is not a full on restoration it will be a race/ ride bike.
Nipper
B-Grade
Reply #4 on:
January 20, 2014, 02:15:03 pm »
http://i1221.photobucket.com/albums/dd469/rm2501977/photo-1.jpg
Nipper
B-Grade
Reply #5 on:
January 20, 2014, 02:17:52 pm »
as you can see its not the best.... the circlip has nowhere to be attached so it was bolted. not the most desirable solution.
TM BILL
Reply #6 on:
January 20, 2014, 03:23:09 pm »
Nipper Pm me your address and I can donate a cush drive part if that helps or sell you a complete hub of either sort
Bill
Marketplace
Wanted
