Author Topic: Rm80 year identification  (Read 9807 times)
Offline jazzablade
« on: January 18, 2014, 08:16:14 pm »
Can anyone tell me what uear my rm80 is frame number is rm80-17270 engine is rm80-17076
Any help cheers people.
Offline Doc
Re: Rm80 year identification
« Reply #1 on: January 18, 2014, 10:27:11 pm »
1977 RM80B. 5 speed , non leading axle forks  ;)
« Last Edit: January 18, 2014, 10:32:42 pm by Doc »
Offline jazzablade
« Reply #2 on: January 18, 2014, 10:53:05 pm »
Thanks mate how you find that out
Offline Doc
« Reply #3 on: January 19, 2014, 12:32:37 am »
I have frame and engine number reference as well as i own one ;) If you are looking for info try here
https://skydrive.live.com/?cid=407d7ef0965d3991&id=407D7EF0965D3991%211086#cid=407D7EF0965D3991&id=407D7EF0965D3991%213199
courtesy of Luke.
Offline jazzablade
« Reply #4 on: January 19, 2014, 07:01:21 am »
Thanks for that handy info there you dont have any parts for sale do you?
Offline Doc
« Reply #5 on: January 19, 2014, 08:43:37 am »
No problem. I do have some bits, what parts are you chasing?
Offline jazzablade
« Reply #6 on: January 19, 2014, 08:45:12 am »
I need right handsode crank case has a crack in it and original muffler whats parts have you got i may need more
Offline Doc
« Reply #7 on: January 19, 2014, 11:41:27 am »
hmmm..apart from original plastics those 2 items (rh case and muffler) are probably next the most sought after parts for the 80B. Mufflers you'll really have to keep you eyes peeled on ebay and such. Sometimes a seller may list a pipe with the muffler in place not knowing it's value. '77 B /'78 C same part.
I've had the right side case welded. Cracking around the kickstart cast stop/idler gear carirer area is near 100% assured on all but extremely low hour examples.
Had a few welded by Bushell Engineering in Bris. northside. http://www.bushellengineering.com.au/ with good results (but my 80's don't get flogged mercilessly like they once did ;D) When looking around also keep in mind the 80B engine numbers ran from 10001 - 23193
« Last Edit: January 19, 2014, 11:43:28 am by Doc »
« Reply #8 on: January 19, 2014, 01:15:02 pm »
Doc - was there an RM80A - in 76 - to match the YZ80C?
Offline Doc
« Reply #9 on: January 19, 2014, 01:20:43 pm »
No RM80A. In '76 it was still TM75. Hardly a match for the YZ80C  ::)
Hypothetically..if ever there were an RM80A the b&w pic above would be close. It shows a pre production model. Different shape tank and sidecovers, no chain tensioner and the front forks/triples also differ from the production model  ;)
« Last Edit: January 19, 2014, 01:25:26 pm by Doc »
« Reply #10 on: January 19, 2014, 02:57:10 pm »
ta - thats what I thought - was a kid racing at the time and the first one I saw was the RMB - YZ80C's before then cleaning up everything.  They were rare as hens teeth where I was and I lusted after one soooo bad
Offline jazzablade
« Reply #11 on: January 19, 2014, 03:10:41 pm »
Thanks again for the info doc you know ur stuff about these litle bikes if u come across those parts im after let us know mate
Offline jazzablade
« Reply #12 on: January 19, 2014, 04:51:02 pm »
<iframe width="480" height="360" src="http://s29.photobucket.com/user/jazzablade/embed/slideshow/Mobile%20Uploads"></iframe>
Any chance of fixing that crack its pretty back peaces are just sitting there broken.
