Author Topic: 1984 kx500 replacement ignition coil pack (twin lead type)  (Read 8270 times)
Offline ghostrider
« on: January 16, 2014, 09:45:06 pm »
  Does anyone know if a replacement ignition coil exists for this model kx500. These are the twin leads that are attached on a single coil.All of the OEM replacements I have found  for  the 84 model only have a single lead ,, I have also researched many kawasaki dealers and come up blank. Any help would be appreciated.
Re: 1984 kx500 replacement ignition coil pack (twin lead type)
« Reply #1 on: January 16, 2014, 11:45:26 pm »
You can buy universal twin lead coils, can't see why they wouldn't work.
Offline Bumper
« Reply #2 on: January 17, 2014, 07:47:23 am »
most suzuki dr650,s run a twin coil pack still today
« Reply #3 on: January 17, 2014, 07:49:42 am »
RD400 coils are twin plug, use 1 on my hybrid ts ignition on the CZ
Offline HVA61
« Reply #4 on: January 17, 2014, 07:54:31 am »
penton Racing products do a complete PVL ignition for that model , it may be worth contacting them and asking if the coil is interchangable and compatible with the original Kawasaki ignition .   KX 500 (approx. 84-87) Plate measures 94mm/3 3/4 “ from center of holes )
Part number 70151
« Reply #5 on: January 17, 2014, 09:50:32 am »
try Steve at Two stroke Shop last one I got was $35 for a 90mm bolt hole twin plug coil
Offline ghostrider
« Reply #6 on: January 17, 2014, 11:02:31 am »
 Thanks Gents , will try out a few of your suggestions.
Offline Stevo17
« Reply #7 on: April 20, 2014, 10:56:16 am »
Have a look on ebay for snowmobile coils.  Many two stroke snowmobiles use twin plug coils.  I purchased an aftermarket coil for a Yamaha snowmobile that looked and fitted exactly like a 84 KX coil. I gave it to a mate that is using it on his bike. Costs about $30 new.
http://www.ebay.com.au/itm/YAMAHA-SNOWMOBILE-1977-EX340A-NOS-IGNITION-COIL-/271459458689?pt=Snowmobile_Parts_Accessories&hash=item3f343e9e81
http://www.ebay.com.au/itm/YAMAHA-VK540-II-1993-1994-1995-1996-1997-1998-IGNITION-COIL-SNOWMOBILE-/291037761813?pt=Snowmobile_Parts_Accessories&hash=item43c333d115
« Last Edit: April 20, 2014, 11:08:42 am by Stevo17 »
Offline 490 tez
« Reply #8 on: May 05, 2014, 05:04:58 pm »
rz 350 coil same numbers same bolt spaces as well works fine
big bore two strokes rock!!!!!!!!
Offline Dave Mc
« Last Edit: August 25, 2014, 08:17:38 am by Dave Mc »
