Author Topic: '84 -' 85 XR200, XR250 or XL250 RFVC Rocker Arms and Inlet Manifold  (Read 1887 times)
Offline 4stroker
G'day people, I have an '84 XR200 that I am trying to get going.  This is the model with the RFVC head and twin carb, the same as the '84-'85 XR/XL250..  What I am after is the two rocker arms on the LHS of the engine, furthest away from the cam chain.  I am led to believe that this is a common weak point on this model, so someone must have an old head or at least the rocker cover with the same symptoms, the rocker arms are interchangeable from left to right, so if you have a head or cover with two good rocker arms, I'd like to buy it!
Thanks, Mark
