Author Topic: KLX250 Front Brake Upgrade  (Read 5808 times)
Offline grouty
« on: January 09, 2014, 02:04:08 am »
Is there another front wheel that fits the KLX250 (79-82). It does not matter what I try, the thing is pretty useless. I have put up with it for many years, but I feel I need to do something different. I do not want to go down the disc brake route, or fit different forks. I would like it to look as stock as possible.
Would the front wheel / backplate assembly from a KDX420 / KDX450 fit ? I know the bearings etc will be different. The main issue would be the width of the hub / backplate compared to the KLX one. If it is too wide to fit between the fork legs, it will be a non-starter.
Has anyone done similar ?
Thumpers Rule !
Offline kdx Geoff
Re: KLX250 Front Brake Upgrade
« Reply #1 on: January 09, 2014, 12:10:11 pm »
To try and add some additional information....
l think the klx250 and the kdx175 share a front end, the front brakes are the same by part number.
The front brakes are the same on the kdx250 B2, the 420 and the 450 and the 3 models look like they share the same front end.
My 250 is the 1983 to 85 model which changed the fork/brake backing plate relationship from the earlier models so l cant check that fit for you but if you could swap a larger brake onto the 175 from a different model l think a few people might have done that  :)....... Has anyone done that ?
Geoff
Offline Paulsky
« Reply #2 on: March 18, 2014, 04:42:37 pm »
I used a set of wheels off of a KDX 400, they have bigger brakes, bigger spokes and are DID rims so all round are better, they're magnesium too! Also they bolt right on
Offline kdx Geoff
« Reply #3 on: March 18, 2014, 05:53:57 pm »
On a 175 or klx ?
« Reply #4 on: March 18, 2014, 09:20:14 pm »
ive seen yz dls wheels on them for improved brake performance...anything else would be an improvement!!! ;D
Offline grouty
« Reply #5 on: March 19, 2014, 06:02:17 am »
Thanks Paul. I will search for a KDX400/420 front wheel. I have found a couple, but they are in the U.S. for silly money, and the shipping is expensive too.
Thumpers Rule !
Offline kdx 175
« Reply #6 on: March 19, 2014, 09:10:29 am »
i have a 83 kdx 200 in my175 there 6 mm wider in the drum makes lots of differenc  its a big job forks are 38 mm made new tripel clamps
