Author Topic: polishing tanks  (Read 2795 times)
Offline LeighW
polishing tanks
« on: January 05, 2014, 01:50:39 pm »
hi finished sanding whats the best polish to use on a tank cheers leigh
Offline David Lahey
Re: polishing tanks
« Reply #1 on: January 05, 2014, 03:14:49 pm »
If you are talking aluminium tank, the white polishing bar
previous pseudonym feetupfun
Offline LeighW
Re: polishing tanks
« Reply #2 on: January 05, 2014, 03:25:21 pm »
sorry forgot to say its a cr plastic  cheers
Re: polishing tanks
« Reply #3 on: January 05, 2014, 03:38:55 pm »
Start off with jif, then I use a plastic polish from meguires to finish off. If you're using a lambs wool pad on a drill, be careful as you can build up a fair bit of heat quickly and melt the tank.
Re: polishing tanks
« Reply #4 on: January 05, 2014, 03:49:51 pm »
have a look at the Meguiars pads as well leigh - shaped to avoid side burn also.
Offline JIM77
Re: polishing tanks
« Reply #5 on: January 05, 2014, 11:26:34 pm »
Does this method work on white plastic tanks?
Offline frostype400
Re: polishing tanks
« Reply #6 on: January 06, 2014, 12:18:10 am »
It will do you might not get rid of staining but you will be able to polish it the same as a tank of any colour, thanks Michael.
1971 tm400 and PE's
