Author Topic: DT 360 kick back  (Read 9064 times)
Offline ty4
DT 360 kick back
« on: January 01, 2014, 07:40:48 pm »
has nice blue spark but kicks back  even  when slowley kicking thru....even tried to fully retard the timing but zero change
all contacts are clean and the magnets in the flywheel are where they are supposed to be...could it be the trigger/pulse coil ?
 the last time i started it ( 12 months ago) it ran fine...frustrating
tony
Offline Canam370
Re: DT 360 kick back
« Reply #1 on: January 01, 2014, 08:10:23 pm »
Hasn't sheared the flywheel key Tony? Timing could be anywhere if the flywheels slipped on the crank.
Offline ty4
« Reply #2 on: January 01, 2014, 09:49:11 pm »
Nah Paul all the basics are as they should be....have a yz internal rotor system i may try instead
« Reply #3 on: January 01, 2014, 10:32:48 pm »
Tony I think you will need the flywheel weight to run properly .
Offline Rookie#1
  • JUST SHUDDUP AND RIDE IT!!!
« Reply #4 on: January 01, 2014, 11:13:21 pm »
Keep them handlebars turned to the left and prepare the neighborhood for the language lesson they're about to get!! ;D ;)
Offline mitch75
  • Newcastle NSW
« Reply #5 on: January 02, 2014, 11:40:22 am »
Check the pulser.  Had bad kick back on my 360a pulser was out.  Check out rexs speed shop has some good info on them.
Yamaha DT360a DT250b DT100c YZ400D WR250ZG.
Offline Spanish Armada
« Reply #6 on: March 27, 2014, 10:10:40 am »
Just noticing in the last 12 months a lot of people having trouble with kickback which they did do but fit up a DT 400 electronic ignition on any 250/360 that has points and all is solved no more sore feet or calf muscle ;D.It is such an easy fit up cheers
Offline ty4
« Reply #7 on: March 27, 2014, 03:23:33 pm »
Put the ignition from a yz 250 c in and away we go..has no bottom end any more but away we go  ;D
Offline von_sieben
    • STOLEN garage co
« Reply #8 on: April 01, 2014, 06:38:31 pm »
sorry, might be a dumb question, but i have no idea of all that electric stuff... which one will fit, ignition from type 512, or dt 400 mx? can i do that on my dt-1 E and my rt-2, too? what exactly do i need? thanks a lot.
Offline vandy010
  • #789 MX125a BMCC Brisbane
« Reply #9 on: April 01, 2014, 07:37:15 pm »
some other Yammie stuff will bolt straight in and others may need a bit of physical "tweaking" to get them to bolt in...
i know for a fact that the DT400 CDI set~up is a straight bolt in (stator plate/flywheel)
the early (74' 75' 76') YZ stuff should bolt straight in as well but they are internal rotor types and may
result in a loss of bottom end power as the flywheels are much lighter...
I'm not sure about IT ignitions...
my RT1 uses a YZ490 system but needed some surgery in the lathe to make it all happen, {only because i had it laying around}
hope this helps...
"flat bickie"
« Reply #10 on: April 01, 2014, 07:53:41 pm »
The DT400 and MX400 and YZ400 cdi systems up till and including 1978 will fit the DT1, DT2 and DT3's also the RT 1 , 2 and 3's  . as well as fitting the DT360's bolt up no messing about on all of them . Iain
Offline von_sieben
    • STOLEN garage co
« Reply #11 on: April 02, 2014, 07:07:27 am »
thanks a lot guys. i assume when talkin about dt 400 you mean the type 512, 6 volt,  not the first cantilever model which was called dt 400 MX over here in germany?
Offline vandy010
« Reply #12 on: April 02, 2014, 07:27:55 am »
The cantlever model will also fit and more than likely be the better option ;)
"flat bickie"
