Author Topic: 30 and 32mm Mikunis.  (Read 2592 times)
« on: June 09, 2008, 06:18:54 pm »
Prefer the 30mm one to come from a YZ125C, but don't really care. DT360A carb does NOT help me.
Prefer the 32mm to come from a YZ125D, E or F, but don't really care.
Will also consider 34mm.
I have a 38mm(?) carby from an early 1980s YZ250 or IT to swap, if that helps. Good nick. Stamped 25Y, I think.
Also have several 24~26mm Mikunis from DT125s and 175s if they have any value to anyone.
04000 23847 if you can help.
Re: 30 and 32mm Mikunis.
« Reply #1 on: June 09, 2008, 06:22:14 pm »
nathan
i have a 30mm mikuni in good condition but the od on the inlet side is small that size do you need.
« Reply #2 on: June 09, 2008, 06:51:24 pm »
Anything down to 34mm OD will be fine (34mm OD is unlikely...).
« Reply #4 on: June 09, 2008, 09:17:17 pm »
Too big, but thanks for the thought Jake.
Edit: Oops - should actually follow the link before replying, rather than just assuming that it was the 250D carby on ebay.com.au.... :-[
Thanks Jake, but this project is not deserving of hundreds of dollars of new carby.
« Last Edit: June 09, 2008, 10:18:55 pm by Nathan S »
Doc
« Reply #5 on: June 09, 2008, 09:36:56 pm »
I know I've harped on about this before but physically look in the bore and feel in the bore for a tpaer ??..oops..a what!!..a TAPER I meant..do it 'before' you measure. Regular vernier calipers don't reach the tapered area which is where a more accurate measurement is taken. If it's tapered you can detract about 2mm on average from the measurement you get if measured at the outlet edge and not closer to the slide area. I reckon for this reason alone people have trouble jetting carbs that are not what they appear..yeah yeah..bla bla..sorry, please continue  ::)
« Last Edit: June 09, 2008, 09:39:32 pm by Doc »
« Reply #6 on: June 09, 2008, 10:15:02 pm »
Yeah, I'm onto that one. I've actually got a series of washers which I use as carby size gauges.
lms6201
« Reply #7 on: June 10, 2008, 05:48:36 am »
nathan i have a 34mm mic in bits but should be all there except for the slide stop and a 34 mm tm if u want to play with a flat slide ,i think it is from a kdx 200 , will swap all for the 38mm , steve 0142708957
