Clubroom
Tech Talk
KX500B1 replacement carb?
Topic: KX500B1 replacement carb? (Read 2199 times)
VMXSteve
Novice
December 18, 2013, 03:45:22 pm »
I have a 1985 KX500B1 with an old original Mikuni VM40 carb that I would like to replace / upgrade due to jetting issues. Jets / Needles are almost impossible to get and I have had great success with the JD Jetting Red needle on my RM250K8.
I can get a new Keihen PWK 38 Airstriker carb with JD Jetting needles etc from the States, but are unsure if it's a straight bolt on solution? Or do I need air box adapters etc....
Anyone tried this on a KX500?
Thanks Steve
YZ250J, KX500B1, XR600RJ, RM250K8, LTZ250K9, DR650SEK9, GSX1400Z, TTR125, GPX250RII, TSX125, TTR50, LTZ50
Nathan S
Superstar
HEAVEN #818
Re: KX500B1 replacement carb?
December 18, 2013, 04:32:10 pm »
FWIW, I put an old round slide Mikuni into a 95 YZ250 (that originally had a 38PWK).
Can't recall how good the fit was (stretched boots, etc) but it definitely went in without the need for adaptor rings, etc.
Stevo17
A-Grade
December 18, 2013, 05:28:26 pm »
You could try a Mikuni TM38-86 Flat slide that should bolt straight on. Jetting would be as stock on the 84 KX500.
Ted
December 18, 2013, 08:16:08 pm »
That's what I've got
81 YZ 465 H 77 RM 125 B
Clubroom
Tech Talk
