Author Topic: AV GAS shell 100 LL, 104 RON?  (Read 4271 times)
Offline oldyzman
  • 250 two stroke!
« on: December 16, 2013, 09:12:47 pm »
How long will this last in a closed drum in a stabil temp 20 to 25 degrees?
I am using Motul 800, at 30:1 seems OK, in a 250 2 stroke 78 model it seems to run quite hot though even with a massive main jet...
Offline FireKwaka
Re: AV GAS shell 100 LL, 104 RON?
« Reply #1 on: December 16, 2013, 09:16:24 pm »
I had some that sat for 2 years, it ran fine and no damage.
83 KX500, 83 RM250D, Can Am MX2.
Offline kim80y
« Reply #2 on: December 16, 2013, 09:52:00 pm »
Sounds like a group buy could be in order??
MMM Love the gas.
Kim 8)
Offline oldyzman
  • 250 two stroke!
« Reply #3 on: December 16, 2013, 09:56:14 pm »
Not too hard to buy, $2.20 per litre
Brett
Offline SON
« Reply #4 on: December 23, 2013, 10:26:37 pm »
Running hot could be combustion chamber ?
Ignition timing ?
More info and the brains trusts might help
Offline oldyzman
  • 250 two stroke!
« Reply #5 on: December 24, 2013, 12:01:52 am »
I will check my notes recomp squish and ccv... and write it up..
Offline big mac
« Reply #6 on: December 24, 2013, 07:32:27 am »
Check the timing with a strobe light. Had a lot of trouble with a yz400d running hot, static timing was spot on but with the strobe way off the cdi box was playing tricks  not letting the sparks go at the right time.
Rory
« Reply #7 on: December 24, 2013, 08:21:33 am »
Rory
Amen to that Rory.
