Author Topic: Twin leading shoe on TS or TM  (Read 4542 times)
Offline ninjamk
« on: December 11, 2013, 11:09:40 am »
Does anyone know if there are any twin leading shoe brake drums that will fit in a TS or TM250 hub?  I am looking at a T500 drum and going by the pics they look like a close match, but I don't want to buy one and find out it doesn't work.
Thanks!
Bikes: 1972 TS/TM250, 2007 KLX300, 2016 GSX-S1000
Offline matcho mick
    • Moto Tumbi
Re: Twin leading shoe on TS or TM
« Reply #1 on: December 11, 2013, 11:44:54 am »
T500?,susy roadie twin 500 toee,just laced a front,it's 200mm inside dia,it's a biggie!!,wouldn't think the 250 suzy would fit either, :P
Offline cyclegod
  • Sunny PERTH W.A
    • cyclegod on "youtube"
« Reply #2 on: December 11, 2013, 12:50:06 pm »
Early TS250 and GT185 shared a double lead shoe hub
Heres the one I used to own...
Ban BLACK rims NOW
Offline ninjamk
« Reply #4 on: December 11, 2013, 02:03:49 pm »
That's exactly what I was looking for.  So to confirm, the GT185 brake plate should work with 72 TS250 hub?
Thanks again
Offline cyclegod
  • Sunny PERTH W.A
« Reply #5 on: December 11, 2013, 07:59:53 pm »
Thanks again
I think 69-71 or 72 whenever Suzuki stopped using the steel fork lowers, I wouldn't think a full hub would be hard to find.
Ban BLACK rims NOW
Offline ninjamk
« Reply #6 on: December 12, 2013, 01:26:25 am »
Thanks cyclegod, I currently have forks with the steel lowers, they look exactly the same as the 69-70.  part numbers on the hub are different but I am going to take a chance anyway.  Worse case, I end up getting a new hub.
« Reply #7 on: January 03, 2014, 11:10:43 am »
I'm doing up a 69 TS250 for dirt track duties (pre 78 250 class at my local track).  To keep the weight down, I've replaced the steel forks with '77 TS250 forks and the steel rim for the al hoop.  But I kept the twin leader brake by 'adapting' and wiring in the original and the later TS spokes.  Saved about six kg as a result.  The brake works quite well, but may replace the shoes with more modern ones for even better bite.
Also replace the rear wheel with an early 70's MX wheel/brake setup - another six kg saved.
Its got an early TM top end, carb and aftermarket chamber for a few extra horsies.  Still got original shocks (with damping!), seat and tank.  And is still a heavy beast.  But looks pretty cool.
« Reply #8 on: January 03, 2014, 11:52:18 am »
can we see a pic ;)
