Author Topic: it dont look much now  (Read 3630 times)
Offline paul
« on: June 07, 2008, 03:07:58 pm »
but ive got most off the bit i need for my franken bike
had the 81/82.forks and the triple clamps stem shortened to suit  79 frame the thor swing arm will be here on mon or tues day motor is a  82/ 490 mx engine going  to use the 82 rear wheel with a billet brake hub to suit the thor swing arm (82 hubs are different than 81 ) and bolt it all together to make sure every thing fits then pull it down  and send the frame off to the sand blaster  and go from there
« Last Edit: June 10, 2008, 06:02:14 pm by paul »
Offline paul
Re: it dont look much now
« Reply #1 on: June 10, 2008, 03:58:33 pm »
update thor swing arm and the tank abit more off the puzzel and it now got the same wheel base as a 81 mega 2
« Reply #2 on: June 10, 2008, 07:51:56 pm »
Maybe it'll look like this one day Paul
Offline paul
« Reply #3 on: June 10, 2008, 08:00:40 pm »
silver mmmmm/not sure yet,that one above looks like a reed 250 btw yes walter i  know
« Last Edit: June 10, 2008, 08:04:00 pm by paul »
Offline Wombat
  • Gold Coast hinterland
« Reply #4 on: June 10, 2008, 08:32:26 pm »
If you're after ideas for colours have a squizz at the yellow '81 Maicos in the latest pommy 'Classic Dirt Bike' mag.
They're more than bikes, they're Hornbags!!
"Whadaya mean it's too loud?! It's a f*ckin' race bike!! That pipe makes it go louder - and look faster!!"
Offline crabman
« Reply #5 on: June 10, 2008, 11:50:10 pm »
Hi Gents
I am looking for some advice. I have a duplicate Maico Alpha 1 single shock 250 (completely restored). I have a part restored Maico 440 frame without a complete motor ( do have cases, barrel, head). I have considered using the complete 250 single shock  bike as a donor bilke and converting it into  a twin shock Maico 250cc.
Obviously the motor and frame will not match, The motor is from an 1982 single shocker, the frame probably late 70' S.
Any suggestions ?
Alternatively will the 440 barrel slip onto the block of the 250 ? Do the motor swop with the 440 barrel, head and pipe ?
Once again any suggestions ?
Many thanks
Gavin w
Old and slow - and happy
Offline paul
« Reply #6 on: June 13, 2008, 04:08:31 pm »
what year is the 440 frame/bike
