Author Topic: 490 into 465 frame?  (Read 1948 times)
Offline Sorelegs11
490 into 465 frame?
« on: December 09, 2013, 12:54:32 pm »
Can anybody tell me if an IT 490 engine will fit straight into an IT465 frame?
Cheers Darren
Re: 490 into 465 frame?
« Reply #1 on: December 09, 2013, 12:59:08 pm »
Can't see any reason why not seeing as bottom ends are likely to be basically the same
Offline FourstrokeForever
  • AKA Mark H #35 VCM
« Reply #2 on: December 09, 2013, 08:18:34 pm »
It will fit. I've put a IT250K motor into a IT250G frame and it bolted straight in. The big bore motors are identical bottom ends externally to the 250's so based on that, you won't have a problem. Unless you have a centre port 490 motor that might have some header pipe/ frame clearance issues.
Offline Sorelegs11
« Reply #3 on: December 10, 2013, 08:49:49 am »
Thanks men I had an idea that it would fit but taking the gamble factor out saves some time.  ;D
