Author Topic: YZ465H and YZ250H frame and swingarm differences  (Read 2165 times)
Offline bishboy
  • Toowoomba
« on: December 09, 2013, 10:11:46 am »
How different are the YZ465 and 250 H model frames and swingarms?  Is the geometry, wheelbase etc all the same or similar enough not to make a difference?
If I had a 250 frame could I put the everything from a 465 in it, engine, airbox, swingarm etc
Re: YZ465H and YZ250H frame and swingarm differences
« Reply #1 on: December 09, 2013, 10:58:48 am »
Pretty sure it's been explained before as being the same frame etc, I was going to say that the front mounts may be different but if you check numbers for gaskets & engine covers etc they're the same so it should be a straight swap
Someone like Ted or YZ250H will know for sure
Offline Ted
« Reply #2 on: December 09, 2013, 12:28:44 pm »
Same frame and swingarm
81 YZ 465 H   77 RM 125 B
Offline bishboy
  • Toowoomba
« Reply #3 on: December 09, 2013, 02:39:02 pm »
Thanks for that, I thought they were, but just wanted to check  ;)
