Author Topic: KX250 A5 Ignitions  (Read 5317 times)
Offline Tahitian_Red
  • Mugen ME480
KX250 A5 Ignitions
« on: December 07, 2013, 10:45:58 am »
What ignition do you run in your KX250 A5?   I can pick up an NOS stock setup (expensive) or should I go with a PVL?   Something else?
« Last Edit: December 07, 2013, 11:21:38 am by Tahitian_Red »
The "Factory Novice"
California, USA
Re: KX250 A5 Ignitions
« Reply #1 on: December 07, 2013, 01:22:17 pm »
I run stock on my A5's, only because that is what they came with.  I've heard there is something better & cheaper than PVL, now I just have to remember what it is  :-/
Offline kdx 175
« Reply #2 on: December 07, 2013, 02:06:05 pm »
« Reply #3 on: December 07, 2013, 03:58:45 pm »
I use the std ignition on my A5, I wouldn't bother with a PVL I put one on my 490 maico and had nothing but trouble so I put a motoplat back on. PVL's are over rated compared to Jap cdi's.
Those Electrex ignitions from the UK may be a better option but if it was mine I'd put an original KX ignition on it.
« Reply #4 on: December 09, 2013, 10:36:48 am »
Any ignition will do the job what you have to have is the right amount of advance which all depends on the curve pre-set into the CDI. Standard CDI's are a compromise between off the pipe and peak performance , backed off a bit for safety. A Hitachi ignition of a YZ work very well and have a good curve installed.
« Reply #5 on: December 09, 2013, 11:47:09 am »
I guess I'm happy with my stock A5 ignition, the 250 has holeshot 'Open Evo' races so it can't be too bad?
  • Mugen ME480
« Reply #6 on: December 09, 2013, 12:55:13 pm »
Stock is OK with me it is just that the rebuilt motor is ignitionless at the moment and I am free to go any direction.  I guess I could also take the working ignition off the current motor (it does run).
California, USA
« Reply #7 on: December 09, 2013, 06:26:12 pm »
........but can it be improved? Old High Voltage CDI's have been eclipsed by DC/DC ignitions providing greater power to the plug, run richer mixtures and get more mid range.
Offline FDR
« Reply #8 on: December 09, 2013, 08:43:46 pm »
HPI may be another option,
I run standard set up on my A5 250 which has worked well for many years
« Last Edit: December 09, 2013, 08:46:07 pm by FDR »
« Reply #9 on: December 09, 2013, 10:15:44 pm »
HPI work well
