Author Topic: mounting pfr pipe on cr 250 80 mdl  (Read 2298 times)
Offline LeighW
« on: December 05, 2013, 08:04:52 pm »
mounted my pipe all fits except rubber mount under tank is to short to get to the pipe mount  is this normal and do you just make a bracket between both cheers leigh
Re: mounting pfr pipe on cr 250 80 mdl
« Reply #1 on: December 06, 2013, 08:22:19 am »
Unfortunately PFR pipes rarely fit (any make or model) without any mod's or rectifications.
« Reply #2 on: December 06, 2013, 08:31:24 am »
I've got two PFR pipes, for the same model KX250's, had to do different cut & shut mods to each of them.
Simo63
« Reply #3 on: December 06, 2013, 09:00:41 am »
My experience with the 2 new PFR pipes I have purchased and fitted over the last 2 years have been poles apart.  Both have included the PFR alloy muffler as well.
On my YZ400D the pipe just fell on .. no modifications required at all, a perfect fit.  Couldn't be happier.
But on my YZ250D I had to make/source different insulated pipe mounts but that was after I had to grind some of the cylinder head fins away by as much as 10mm at the rear of the head.  It was such a bad fit I called the supplier to let them know they had sent the wrong pipe but alas it was the right one  :o
« Reply #4 on: December 06, 2013, 09:33:59 am »
Leigh - havea PFR pipe on my 80 model - will see if I have any photos at work to send through - although wont help what you still have to do.
Offline LeighW
« Reply #5 on: December 06, 2013, 04:16:02 pm »
thanks for the replies its 10-15 mm between the hole in the bracket and the rubber mount hole im just going to put a small alum piece to lengthen the bracket cheers leigh
Offline Ted
« Reply #6 on: December 06, 2013, 06:33:09 pm »
Grinding fins. Changing external appearance of motor. You'll get protested 8)
81 YZ 465 H   77 RM 125 B
