Author Topic: Arc welding to a truck body?  (Read 5121 times)
« on: November 28, 2013, 12:20:35 pm »
Hey Guy's,
I bought a truck to haul the vmx'ers around, I want to weld in tie-down hooks & stuff.  Can I just weld away or do I need to disconnect all the electrics?  Any help would be appreciated, thanks.
Offline kdx Geoff
Re: Arc welding to a truck body?
« Reply #1 on: November 28, 2013, 12:31:01 pm »
Hi John,
The alternator may not like the welding, if you disconnect the battery that usually takes care of the electrics.
Your truck is a diesel, yes ? So you shouldn't have much more to worry about.
If you want to be thorough, you could stick your head under the dash and the kick panels and unplug any computers/cpu's it might have.
Geoff
« Reply #2 on: November 28, 2013, 12:38:49 pm »
Make sure your esrth connection point is clean and as close as possible to where you are welding
never put it in a place that is just convienient as the current may return via some wiring on the truck and melt it.
Offline vandy010
  • #789 MX125a BMCC Brisbane
« Reply #3 on: November 28, 2013, 01:00:52 pm »
also,
it pays to know whats behind the welded area as well...
burnt bits can be a pisser ;)
"flat bickie"
« Reply #4 on: November 28, 2013, 01:13:03 pm »
What the others have said.
Disconnect battery
Nephew got 20 min. down the road before he realized the carpet was on fire from having just welded the exhaust.
If welding a chassis then put the earth on the chassis, if welding the body then put the earth on the body.
Same with bikes, if welding the swingarm then put the earth on the swingarm not the frame otherwise the current will travel through the bearings or shocks. If it does it will create an arc strike on the bearing surface rendering said bearing forked.
Haven't had to weld anything on a modern car of late but if I did I would also be disconnecting the computer
Offline hagon_84
« Reply #5 on: November 28, 2013, 02:36:48 pm »
snap on make a really good battery isolator which connects to both pos and neg on battery and it has lights on it to tell u if system is isolated and ready to go to weld i use quiet regularly (smash repairs) but if its a one off disconnect  battery like others said  ;D
AL.
1977 Hagon rm250b, 1977 yz400d, 1972 gauzonni rm125, 1969 greeves griffon 250, 1973 greeves griffon qub 380, hagon eso 500.
« Reply #6 on: November 28, 2013, 02:38:25 pm »
Thanks Guy's  :-)
« Reply #7 on: November 29, 2013, 09:27:52 am »
Diesel spark plugs don't like the amps so take those all out before you start.
Offline FourstrokeForever
  • AKA Mark H #35 VCM
« Reply #8 on: November 29, 2013, 10:03:18 am »
Hmmm, diesel spark plugs hey  ;D  ;D  ;D  ;D
I think you mean glow plugs.....
John, I did the same thing on my Iveco when I was doing the bike transport and all I did was disconnect the battery and unplugged the computer. I didn't have any dramas at all. Mind you, I did use a Mig welder
« Reply #9 on: November 29, 2013, 10:22:23 am »
what heat range spark plugs should I be running in my Dutz enduro motorscooter, in the winter and in the summer and can I do plug drops to check fuel/air mixture and should the tailpipe run grey ???
« Reply #10 on: November 29, 2013, 05:26:22 pm »
42, yes and black sooty black ;)
« Reply #11 on: November 30, 2013, 10:49:02 am »
Ah good cos I was a worried as it has a bit of a rattly knock  ;)
