Author Topic: disc brake question for my sliderits getting there)  (Read 4143 times)
« on: November 27, 2013, 08:56:48 pm »
i have a lhs i would say clutch m/c to mount on the handlebars
not had much to do with disk brakes
could i use the clutch upside down on the rhs
would this work and not leak
jim
Offline GD66
Re: disc brake question for my sliderits getting there)
« Reply #1 on: November 27, 2013, 08:59:16 pm »
Wouldn't be great, Jim. Hit the wreckers, surely you can dig a right-hander up off an old Honda...
« Reply #2 on: November 27, 2013, 11:19:24 pm »
jim
The brake hose would fill with air as soon as you rolled it over..
« Reply #3 on: November 27, 2013, 11:28:27 pm »
jim
It shouldn't - bleed it on the LHS bars, fill the reservoir right up, put the cap back on, then move it over to the RHS bar.
But yeah - brake MCs can be had cheaply enough that I wouldn't bother.
Plus some clutch MCs don't use brake fluid, and you'd need to check out bore sizes.
Offline Ktm181
« Reply #4 on: November 28, 2013, 10:56:26 am »
jim
No. It would uncover the ports over the piston which means gobs of air in the system, or at least it should!
Kt.
Offline KTM47
« Reply #5 on: November 28, 2013, 01:07:10 pm »
jim
I was at the Australian Senior Track Championships a week or so ago.  There was a slider there with three levers on the clutch side.  They were clutch, rear brake and gear change.  Anyway you could use the normal rear brake master cylinder and use a cable to activate it. Just have a short lever.
MAICOS RULE DESPITE THE FOOLS
« Reply #6 on: November 28, 2013, 02:40:53 pm »
my idea is
rear brake on rhs
front brake lhs along with clutch and decompresser leaver
its a longtracker with a 500 meth single yamaha
jim
« Reply #7 on: November 28, 2013, 08:43:05 pm »
jim
Oh is that all, don't worry about it, you shouldn't need brakes....
« Reply #8 on: November 28, 2013, 09:13:04 pm »
YES I DO
wont ever race it on long track just dirttrack in nsw
