Author Topic: PE400 Conrod wanted  (Read 4831 times)
Offline SON
PE400 Conrod wanted
« on: November 26, 2013, 08:35:11 pm »
I can't remember, is there an alternative?
Offline frostype400
Re: PE400 Conrod wanted
« Reply #1 on: November 26, 2013, 09:14:23 pm »
Yes Stewart found one if I am correct it is a sea doo one if some one doesn't chime in with the part numbers I will look it up for you, thanks Michael.
1971 tm400 and PE's
Offline SON
« Reply #2 on: November 26, 2013, 09:33:44 pm »
Thanks Michael I deal with BBI
Just couldn't remember
Offline frostype400
« Reply #3 on: November 26, 2013, 10:39:46 pm »
1971 tm400 and PE's
Offline SON
« Reply #4 on: November 26, 2013, 11:31:37 pm »
I dislike links like that I always feel like someone is invading my computer
Offline frostype400
« Reply #5 on: November 27, 2013, 12:13:35 am »
Ok it is on the pe yahoo group to but it will be the same file.
I am not worried if some one hacks my computer or taps my phone got nothing worth while taking and I am pretty sure that banks take responsibility for any stolen funds any way providing you aren't negligent.
You could however get some one send you what they consider to be a humorous link sometimes much worse than a virus with mentally scaring content fallen for that one before from friends being funny.
Here's plain text from that link,
THIS IS THE ALTERNATE PE400 ROD SOLUTION DESCRIBED BY STEWART ('oldfart')
Rod   =   Seadoo 650  Hot Rod Part #H8117
       ( All the parts below were  supplied )
   Use the Seadoo big end bearing.
   Use the std Suzuki PE400 big end pin.
   Thrust washers =  1 x seadoo supplied in kit against rod, plus 2 Honda Cr 250 ( 84-01 )
   Use the std Suzuki PE400 little-end pin.
   Use the Seadoo small end bearing in top of rod
To get 'real' PE400 rods re-made, a minimum order of 500 is usual.
(ie at around @ US$150-00  = US$75000.00 !)
1971 tm400 and PE's
Offline frostype400
« Reply #6 on: November 27, 2013, 12:18:07 am »
With the thrust washer that's is per side so it is 2 seadoo supplied and 4 cr 250 total to make it work.
1971 tm400 and PE's
Offline SON
« Reply #7 on: November 27, 2013, 05:53:34 am »
Thanks Michael
Remember the older we are the less Computer savvy we are
And more likely to be one finger typists
Offline frostype400
« Reply #8 on: November 27, 2013, 07:53:16 am »
I am no computer expert one finger typing is my Dad's specialty he was worried about using credit card online until I showed him all the parts he could get for his car and then he didn't seem so worried about it, thanks Michael.
1971 tm400 and PE's
Offline SON
« Reply #9 on: February 26, 2014, 05:09:54 pm »
how long is the suzuki big end pin
« Reply #10 on: February 26, 2014, 08:35:26 pm »
Graeme....  yes as per my description it works well .
The reason there are extra thrust washers is because the big end  and small ends are slightly  narrower than Std .
69.80mm   with a  8mm centre hole.  Being a B/E pin  GSP
Offline MaxPower
« Reply #11 on: March 03, 2014, 12:40:06 am »
Thanks Michael
I've spent too much time recovering from injuries and wasting my life in front of a monitor. I've gone from being half illiterate to typing full bore and no peeking.
