Suzuki
TM , RM 125 Down pipes
Topic: TM , RM 125 Down pipes (Read 6301 times)
TM BILL
November 26, 2013, 07:52:19 am »
Dont want to hijack Petes thread but some questions were asked about pipes in the thread .
http://forum.ozvmx.com/index.php?topic=32151.0
The pipe Pete made for his bike is a work of art and a credit to him , and the best S pipe i have seen bar none
Heres a selection of Down pipes for TM , TS, RM 125 M & S models
TM 125 original with pickle muffler , the owners handbook advises you will gain 2 HP if you run without the muffler
TS 125 factory kit pipe , no muffler at all , indentations are to clear footpeg , brake pedal
RM 125M pipe pressed steel construction and small permanently fitted muffler
RM 125S pipe cone construction with small permanently fitted muffler , this one has had a fitting put in the header for dyno tuning
Aftermarket cone pipe with built in muffler , inside the pipe is a reverse cone that ends where the stinger tube starts .
Of all the pipes i have found the S pipe and the aftermarket pipe to give the best performance on TM and RM 125 S .
Last Edit: November 26, 2013, 07:54:57 am by TM bill
TM BILL
Re: TM , RM 125 Down pipes
November 26, 2013, 08:04:52 am »
Pretty sure this is a TM 250 pipe
origin unknown
Lozza
November 26, 2013, 09:12:49 am »
Pipes with distinctive cones always work better than stamped or hydroformed sections. The S looks like it's has a tapered header as well.
GMC
Broadford, Vic
November 26, 2013, 10:16:05 am »
GMC TM / RM chamber
G.M.C. Bringing the past into the future
TM BILL
November 26, 2013, 10:41:16 am »
Quote from: GMC on November 26, 2013, 10:16:05 am
GMC TM / RM chamber
Thats a nice pipe
i have a number of geoffs pipes on my bikes and bikes i have on sold . YZ 125A the GMC pipe for this bike has to be the best bolt on horsepower you can buy
RM 250B bolts straight on and delivers better power every where , i have since sold this one and have another on order
RM 400N another straight bolt up job
RM 125B bolts straight on and gives more over rev than the original
Ted
November 26, 2013, 05:53:30 pm »
WOW a steel arm painted aluminium. Is that legal
81 YZ 465 H 77 RM 125 B
TM BILL
November 26, 2013, 06:38:54 pm »
Ted i was able to provide evidence after much research that the paint was available in 1976
Ted
Reply #7 on:
November 26, 2013, 06:43:13 pm »
OK, Clear to ride. Thru you go.
Vintmxman
C-Grade
Reply #8 on:
December 01, 2013, 11:39:35 am »
How do I get in contact with the builder ? Need a bunch built..
TM BILL
Reply #9 on:
December 01, 2013, 11:45:26 am »
https://www.google.co.nz/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&ved=0CCsQFjAA&url=http%3A%2F%2Fwww.geoffmorrisconcepts.com%2F&ei=WYaaUpa_GMjyiAfkyoC4CA&usg=AFQjCNGFxuWnmHcyDgEnEPCHrUEIiNV2_g&sig2=9OHaBWooLrYEn1hX9FruVQ
Vintmxman
C-Grade
Reply #10 on:
December 01, 2013, 10:16:32 pm »
Thanks TM Bill....
Suzuki
