Author Topic: 1982/83 CR250  (Read 17274 times)
Offline Digga
1982/83 CR250
« on: November 21, 2013, 07:15:19 pm »
Anyone out there able to list the differences between the 1982 CR250 & the 1983 model Honda?
« Last Edit: November 21, 2013, 07:17:57 pm by Digga »
1977 Yamaha YZ250D, 1977 Yamaha YZ400D, 1980 Yamaha YZ125G
Offline mick25
  • Hunter valley NSW
Re: 1982/83 CR250
« Reply #1 on: November 21, 2013, 07:36:43 pm »
A mate of mine has the 83 model  , I think his has a 81 clutch cover on it that is alloy the 83,84 so on are made out of mag and have probs
« Last Edit: November 21, 2013, 08:18:05 pm by mick25 »
Re: 1982/83 CR250
« Reply #2 on: November 21, 2013, 07:52:22 pm »
83 has disc front ,82 has TLS front end , 83 has chain on rear brake pedal side of bike , 82 chain runs on the other side .
kick starter on the 82 is on the gear stick side , 83 is on the other side   , they seemed to change things from left to right between 82,83 :o
 not sure about power changes from the two.
should be someone on here that's knows a bit more than me.
A mate of mine has the 82 model  , I think his has a 81 clutch cover on it that is alloy the 82 and 83 are made out of mag and have probs
What
My 83
Offline oldyzman
  • 250 two stroke!
Re: 1982/83 CR250
« Reply #3 on: November 21, 2013, 07:54:36 pm »
My 83 has 7 head studs....
My 83 has the kicker on the left, 84 is on the right...
Re: 1982/83 CR250
« Reply #4 on: November 21, 2013, 07:57:07 pm »
Thats nothin, mine has seven head stud nuts 8)
Offline mick25
  • Hunter valley NSW
Re: 1982/83 CR250
« Reply #5 on: November 21, 2013, 08:15:42 pm »
oops I got mixed up with the 83 and 84 I was talking about the 84 instead  ??? I had a blonde moment  :o
forget all I said about the models  ;D
Offline Ted
Re: 1982/83 CR250
« Reply #6 on: November 21, 2013, 08:20:16 pm »
You have blonde ass hair ;D ;D ;D ;D
81 YZ 465 H   77 RM 125 B
Offline oldyzman
  • 250 two stroke!
Re: 1982/83 CR250
« Reply #7 on: November 21, 2013, 08:42:12 pm »
Mick D, does the 84 have 7, and the 82, or does the 83 standalone,
BTW I didnt think mine was special, I am more happy that i can count to seven accurately without forgetting where i was up to
« Last Edit: November 21, 2013, 08:44:15 pm by oldyzman »
Re: 1982/83 CR250
« Reply #8 on: November 21, 2013, 08:47:36 pm »
I'm just glad its not me for a change ;D ;D ;D
Mind you,,,you should have seen my face when I couldn't find my disc brake :P
Re: 1982/83 CR250
« Reply #9 on: November 21, 2013, 08:49:39 pm »
 ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D
Yeah the 82 has six head studs and the 84 has Seven.
Re: 1982/83 CR250
« Reply #10 on: November 23, 2013, 10:56:44 am »
82 CR 250
83 CR 250
Obviously the 82 model has had an extra year out on the track
Offline Canam370
Re: 1982/83 CR250
« Reply #11 on: November 23, 2013, 11:06:54 am »
Howzat Geoff! Amazing what you find when you cut the grass  ;D
Re: 1982/83 CR250
« Reply #12 on: November 23, 2013, 11:08:13 am »
Shuddup you, your starting to sound like my wife
Offline Scunge
Re: 1982/83 CR250
« Reply #13 on: November 23, 2013, 02:26:29 pm »
I have a 83, which shares very few parts with the 82 or 84 models.
Some of the differences that I learned when we restored my 83 include:
1. The 82 clutch cover is ever so slightly different (but you can mode the pipe to make it all fit). On this point, the 81 cr clutch cover which is alloy can be adapted to fit the 83 with a bit of work. I did this on my one so I never have to worry about clutch rot!
2. Engine gears are mostly unique for the 83
3. Tank, plastics are different
4. Shock Is different
5. Head and barrel are slightly different
6. Pipe and muffler are different
I would guess that the frame is slightly different. I was lucky to find a good 83 frame and replaced the one I had.
All in all there are more differences than you would imagine. The 83 was really a one off, which was a pain because parts were very hard to find!
Not great when the gear box was fxxked and only one gear was usable!
P.s my cr is the one that gmc posted. I have tarted her up a bit since then with some nos plastic, ohlins shock, etc... It is a bloody good bike!
ST
