Author Topic: 81 kdx175 front brake drum  (Read 6954 times)
Offline tony66
« on: November 19, 2013, 06:18:14 pm »
hi all I was wondering if some one can shed some light on the problem I am having with my 81 kdx175 front brake drum
I have look at drawing and parts list thinking there is supposed to be a wash of some sort in there but nothing anywhere as the lever is jamming on the outer fork tube and the bolt is hitting the top as you can see in the photo. Or is any of it look wrong as in parts or set up and yes I have had the bolt in the other way. I have only ridden for a short time and the brakes felt sh!t so replaced the cable shoes did up the fork and was putting it back together when I noticed this problem.  any help would be great
cheers tony
« Last Edit: November 20, 2013, 07:42:08 am by tony66 »
2004 KLX 300 when put back together
1991 KDX 200 going
1981 KDX 175 almost going
and a kanga which is green to keep with the theme
TM BILL
Re: 81 kdx175 front brake brum
« Reply #1 on: November 19, 2013, 06:35:59 pm »
looks like the wrong arm  :-\ will check on mine tomorrow but i think it should be a cast alloy arm .
Offline tony66
« Reply #2 on: November 19, 2013, 06:38:03 pm »
thanks for that I was hoping it would be something simple
cheers tony
1991 KDX 200 going
Offline kdx 175
« Reply #3 on: November 19, 2013, 07:02:02 pm »
it looks the same as mine but the brakes are shit any way
« Reply #4 on: November 19, 2013, 07:18:30 pm »
It is a tight fit but it should clear okay.
If you have the wrong cable then the arm may be sitting at the wrong point on the spline.
I tweaked mine and my brake works fine.
Offline tony66
« Reply #5 on: November 19, 2013, 08:28:17 pm »
checked all that I got over the problem by cutting a small piece out so that the bolt head is recessed abit and all works fine now I think the bolt may have been a touch on the bigger side now just have to adjust the arm and should have working brakes well as good as any kdx from what people say
cheers tony
1991 KDX 200 going
Offline kdx Geoff
« Reply #6 on: November 19, 2013, 09:09:44 pm »
Hi Tony
you're not the first, a 80's mod to fix that problem on my 175.
Geoff
Offline mustanggrahame
« Reply #7 on: November 19, 2013, 09:52:57 pm »
You can get them to work Tony they just don't like mud.
Cheers, Grahame
Offline tony66
« Reply #8 on: November 19, 2013, 10:06:26 pm »
what have they done there filled in the top and then put a thread into it
looks like a common problem with them maybe why the brakes aren't the best. so what are they like on your bike with the arm like that.
thanks for the photo
cheers tony
1991 KDX 200 going
Offline kdx Geoff
« Reply #9 on: November 19, 2013, 10:31:02 pm »
The top of the bolt has been taken off and the thread brazed into one side of the arm.
Offline tony66
« Reply #10 on: November 19, 2013, 11:26:24 pm »
so the nut is on the bottom then  ???
if so does that mean you cant get the arm off
cheers tony
1991 KDX 200 going
Offline Glen08
Re: 81 kdx175 front brake drum
« Reply #11 on: November 20, 2013, 08:50:20 am »
Hi,
Just checked mine (new to KDX) & someone has ground out a section to alleviate the problem..
I too need cable & shoes,,,,glen.
Offline tony66
« Reply #12 on: November 20, 2013, 09:10:48 am »
yer that is what I done to mine will post a photo later
I am taking it out on the week end so should get a good feel for the bike and brakes
cheers tony
1991 KDX 200 going
Offline kdx Geoff
« Reply #13 on: November 20, 2013, 10:23:34 am »
cheers tony
The nut is on the bottom and l can't recall having taken or tried to take that arm off in the past, l will check it out though.
TM BILL
« Reply #14 on: November 20, 2013, 10:31:44 am »
I got it wrong  ::) the cast arm is on the KX 125 but a KX arm should fit a KDX .
KDX arm
KX arm
