Author Topic: KDX420 or KDX450 flywheel  (Read 3996 times)
Offline Husky500evo
« on: November 17, 2013, 02:02:37 pm »
Anyone out there got a KDX420 or KDX450 flywheel, that they want to sell ?
Re: KDX420 or KDX450 flywheel
« Reply #1 on: November 17, 2013, 08:34:33 pm »
I think early KDX250 is the same also, I just bought one from the States for my KDX400, I'm going to try an internal flywheel this week.
Offline holeshot buddy
  • sunshine coast qld
« Reply #2 on: November 17, 2013, 11:24:12 pm »
what would you want that for mark ::) ::)
follow me to first turn
Offline Husky500evo
« Reply #3 on: November 18, 2013, 06:42:53 am »
I think you've probably got a bit of an idea, Rusty   ;).
« Reply #4 on: November 20, 2013, 04:21:29 pm »
Keep in mind that Zedder gets in wrong on occasions
Part # = 21007-1012
Part Description = MAGNETO FLYWHEEL
Model Count = 5
KDX250-A1 80 250 KDX250 OFF ROAD
KDX400-A1 79 390 KDX400 OFF ROAD
KDX400-A2 80 390 KDX400 OFF ROAD
KDX420-B1 81 420 KDX420 MOTOCROSS
KDX450-A1 82 420 KDX450 OFF ROAD
Flywheels have a code to identify them, it is stamped on the outer face of the flywheel.
I suspect that Kawasaki didn't make their own flywheels and this is a code from the manufacturer
KDX 175 - FP 4180 - 107mm OD - 1.055 Kg (this one has some extra Araldite in it)
86 KDX 200 - FP 5119 ( no compliance)
87 KDX 200 - F4 T100 ( with compliance) - 112mm OD - 1.26 Kg
83 KX 500 - F3 T205 - 118mm OD - 1.42 Kg
83 - 85 KDX 250 FP 5173
The 87 KDX 200 flywheel fits onto my KDX 175 crank to the same position. My memory was that I couldn't use it when I tried to years ago because the rotor and stator are both bigger in diameter.
The KX 500 flywheel doesn't go on as far and sticks out around 5-6 mm when pushed onto the 175 crank, not convinced the taper is the same on this flywheel as it rocked a little bit nut I didn't try that hard to fit it home all the way.
My gut feeling is that most of the early 250 & big bore flywheels will be similar on the taper but may vary in rotor & stator dia.
Personally I am after a 86 - 88 KDX 200 flywheel and stator if you come across any you don't want.
