Author Topic: PE 175 carby's  (Read 4732 times)
PE 175 carby's
« on: November 12, 2013, 04:15:53 pm »
Let me know if you have any lying around VM34 has to be from the PE 175 though
Offline BAHNZY
Re: PE 175 carby's
« Reply #1 on: November 12, 2013, 06:42:33 pm »
Lozza,
What would i be looking for (physically from any other VM34)?
I have a PE175 engine in bits somewhere and i'm sure it came with a carb, trouble is it would be in the box with the other 20 or so.
Rod
Rod (BAHNZY) Bahn
Re: PE 175 carby's
« Reply #2 on: November 12, 2013, 10:49:57 pm »
Rod it is a VM34 but apparently has a 36mm slide, specific to the PE 175. Next time your looking in the carby box  ;D
Offline jimson
  • Sanctuary point N.S.W
Re: PE 175 carby's
« Reply #3 on: November 13, 2013, 10:20:28 pm »
Lozza I would like to help you I have a bakers tray full of carbies  from a job lot I bought a while back. CDI as well and kick starters. I just don't know what is off what.  :-\ jimson
Re: PE 175 carby's
« Reply #4 on: November 14, 2013, 01:57:22 pm »
Lozza,
Rod
hey what PE175 donk is it? as Iam looking for PE175C,N donk bits ;)
Re: PE 175 carby's
« Reply #5 on: November 14, 2013, 05:21:21 pm »
looks like this
40mm @  carb intake OD .....and 34 ID
57mm @  air box OD      ......and  10mm boot area
Should have  PO   91 or 81 stamped on LHS
  http://i72.photobucket.com/albums/i180/mutchoo/001_zps29ff5bf0.jpg
TM BILL
Re: PE 175 carby's
« Reply #6 on: November 14, 2013, 05:37:49 pm »
The only problem i have ever had with my PE 175X was with the carb . The slide locating pin came adrift from the body of the carb and got sucked through the motor . Didn't cause any damage (its aluminium ) but wedged itself between the crank web and the crank case giving the impression that the motor was seizing. Finished a race on it no problem but when i went to stsrt it it wouldn't start , the slide had turned in the carb . kicking it you didn't notice the extra resistance but when turning it over by hand you could feel the binding . Pulled motor down expecting the worst , and found the culprit sitting under the crank web .
Reassembled it fitted new carb and its been good as gold ever since  :) Heres Brad 090 doing things with it that made the enduro purist blush at the Johnny Old  ;D
Offline suzuki59
  • Kiwi VMX
Re: PE 175 carby's
« Reply #7 on: November 14, 2013, 06:49:11 pm »
I can vouch for Bills PE it's a nice bike that can even carry my lard arse around a track ok....
TM BILL
Re: PE 175 carby's
« Reply #8 on: November 14, 2013, 07:27:57 pm »
LOL mate you came over to the dark side  :) if you can get away i will take it to the Greybeards this weekend for you but i will need a ride on that 88 the following weekend  :)
Re: PE 175 carby's
« Reply #9 on: November 15, 2013, 11:27:25 am »
Lozza,
Rod
bump
Offline BAHNZY
Re: PE 175 carby's
« Reply #10 on: November 15, 2013, 02:07:03 pm »
Pete,
No idea what it is. I've got to go down to the storage shed this weekend to drag out a bunch of project's and complete bikes that that i am about to sell off so i'll have a look. I've seen engine number id's for RM's but not PE's. If i get the engine number will that help you ID what i've got?
Rod
Rod (BAHNZY) Bahn
Re: PE 175 carby's
« Reply #11 on: November 15, 2013, 02:20:14 pm »
Pete,
Rod
yer thanks mate numbers good :) ;) hmm projects 8)
