Author Topic: KLX250 swing arm??  (Read 2249 times)
Offline Curtis
    • japspec.com.au
KLX250 swing arm??
« on: November 12, 2013, 12:52:54 pm »
Does anyone know where I can source new swing arm bearing/kit etc for a 81 KLX250? Im having a little trouble finding them.
Cheers!! :)
Offline grouty
Re: KLX250 swing arm??
« Reply #1 on: November 15, 2013, 08:13:35 pm »
No one makes a kit for the old KLX. The bearings and seals are available through commercial bearing suppliers.
It is the steel sleeves that cause the problem. They wear and rust ! These are no longer available. If you do find a NOS set of four, then snap them up. You can always replace the bushes and bearings with a nylon insert as some have done.
There was a thread in the Kawasaki section on this subject a little while ago. See http://forum.ozvmx.com/index.php?topic=31092.0
Thumpers Rule !
