Author Topic: gearbox oil yz 400d  (Read 2358 times)
Offline hagon_84
gearbox oil yz 400d
« on: November 02, 2013, 05:44:35 pm »
the bowx takes 1100cc to fill my question is how much fluid would it retain if u only dropped it thru the drain plug ive topped it back up with the 1100 cc its says to but its way over on the stick would i be best to drain some back out and top to the the bottom of dipstick where the criss cross patern is ? dumb ass me didnt measure what i drain in a rush i drain it into a container with old oil in it  ::)
1977 Hagon rm250b, 1977 yz400d, 1972 gauzonni rm125, 1969 greeves griffon 250, 1973 greeves griffon qub 380, hagon eso 500.
Offline Big Scotty
  • Heaven 380
Re: gearbox oil yz 400d
« Reply #1 on: November 02, 2013, 07:43:50 pm »
A little while ago I put up a post about the correct length that the dipstick should be in one of these,when I fill mine up with the correct amount of oil it goes up about 20mm above the criss cross level mark. My dipstick also hits the bottom of the cases wHen it's screwed fully in which is why I thought I had the wrong one,at Christmas when I rebuild the motor I'm going to fill it up with the correct amount and mark the stick.,hope this helps.
Cheers scotty
yz400d yz125d yz490k
Offline hagon_84
« Reply #2 on: November 02, 2013, 08:17:45 pm »
Cheers Scotty mine is also about 20mm above the cross cross with putting 1100 cc in it should be ok problem owning a bike this old with no manual google brings up shit all help and I got a dirt track meet in mornin
