Author Topic: Protecting polished/buffed aluminium  (Read 12146 times)
Camel
« on: August 19, 2007, 04:04:52 pm »
Blokes,
on your old forum you had a post about a clear paint-on substance that protects polished/sanded aluminium components.
What the heck was it?
Camel
Re: Protecting polished/buffed aluminium
« Reply #1 on: August 19, 2007, 06:01:00 pm »
Was it POR15's 'Glisten PC'?
http://www.ppc.au.com/topcoat_glistenpc.htm
I haven't used it but POR15 resto products have a good reputation.
« Reply #2 on: August 19, 2007, 07:12:15 pm »
it was clear engine enamel.  UHT or power plus clear.
the actual run down on the how to buff the shite out you good stuff and clear coat it is halfway down the pages of the TM rebuild/restore guide.
but if your lazy like me just read it here   ::)>>>>
Item 5 - Lacquered Once you have achieved your desired level of brilliance it is time to provide the surface with a protective barrier. Firstly you will need to meticulously clean all your parts being extremely careful not to scratch the finish you have just completed. Hence only absolutely clean soft cotton rags should be used (ie T-shirt material is excellent). OK, once all polish residues have been removed, wash the surface of the parts with Prepsole or high quality thinners (not turps).
Once Prepsoled, do not touch the parts with your fingers. Paints and lacquers will not adhere to finger acids and oils. Set up the parts on wire or wooden dowel etc to allow you to manipulate them during painting. Purchase a can or two of Power Plus clear engine enamel gloss paint. This product works a treat every time and is also impervious to most degreasers and detergents etc. Shake the can well, then place in a container filled with hot water (not boiling), periodically removing and shaking the can over a period of say 3 - 5 minutes. The warmed paint flows easier, self levels on the surface and sets quicker reducing the chance of runs and/or orange peeling. Being patient is the golden rule here.
Apply 2 or 3 coats of medium density and if necessary, rotate the component (on the manipulator you made earlier remember) to chase out potential runs. You will only need to twirl and weave etc for 10-20 seconds as the warmed paint will "go off" fairly quickly. With mission accomplished as far as the alloy is concerned, let's turn our attention to the fork leg upper tubes. That's right, the chromed bits, or should that read "heavily corroded and pitted parts".
Assuming we are restoring the motorcycle to its former glory, we are left with only two choices
« Last Edit: August 19, 2007, 07:27:32 pm by Freakshow »
Offline RED ALERT
« Reply #3 on: August 19, 2007, 09:18:44 pm »
I've used POR 15 Glisten PC on polished Aluminium and it works quite well. It is a 2 pak product, so you will need to use sray equipment.
Rosco400
« Reply #4 on: August 20, 2007, 09:27:03 pm »
clear powdercoating, looks a treat, give john a call at Prostrip 0249426264 you wont be dissappointed
« Reply #5 on: August 20, 2007, 10:29:48 pm »
thats a new one ? clear powdere coating ? can that be a clear coating also ? like over other finishes ?
Rosco400
« Reply #6 on: August 20, 2007, 10:36:41 pm »
Certainly can, powdercoated straight over bead blasted fork legs. Better than new ;) relatively new product and doesnt go milky like you would expect
« Reply #7 on: August 25, 2007, 09:38:12 pm »
here are 2 sets of PE fork outer tubes i just did. takes a fair bit of work to get a lot of the marks and corrosion out if there is any. a bead blaster helps. we use 2 pack clear paint. did a set for a customers XT 500 this week. originally he said just put new seals in it. we said they would look shit if he put them back on the bike like that, and convinced him to have us polish and clear coat the bottoms while they were apart. you should of seen his face when he saw the finished product. he was very happy to have decided to have them done.
