Author Topic: Modern KX and YZ250F sprockets, levers, etc. Cheap  (Read 1659 times)
« on: June 01, 2008, 09:52:59 pm »
OK, so most of the following might sound a bit vague, but if you're interested, just let me know and I'll give you part numbers and/or measurements so we can be sure that you're getting the right thing.
Kawasaki:
I've got a pile of sprockets that I think will suit any KX or KDX made since the late 1980s. They do NOT fit my 84 KDX200. Different and varied tooth counts (42 to 52 tooth, IIRC). Some new, some used, no rubbish.
Also a heap of clutch lever blades from a new-ish KX125. Again: some new, some good used, some bent but useable as spares, no rubbish.
There's also a 'used but excellent condition' standard pipe from the same late model KX125.
Heaps of brake pads. Most are genuine Kawasaki, most are new. Front and rear.
Yamaha:
Various front brake levers from 07 YZ250F. Two used, two new, IIRC.
Heaps of used clutch plates and springs. Some are barely used, some a quite sad.
There's also other bits and pieces like a net set of rear brake pads to suit a KX80 (and a whole heap of quads, apparently?), an air filter cover, standard disc guards, etc.
Price: Cheap.... As always, I'd prefer to see this shit go to someone who will use it, rather than have it clutter up my shed.
Even better, I'd really prefer to swap for old Yamaha or Suzuki bits (see Wanted section for the Suzi bits I need).
04000 23847 or PM me.
