Author Topic: TS185 and TC100 bits.  (Read 3458 times)
« on: June 01, 2008, 09:35:48 pm »
Bits needed to suit 1974 TS185L:
Rear spoke set, or good complete rear wheel.
Exhaust heat shield.
Front guard (orange).
Chain guard.
Seat cover (pending Pokey's success in finding contact details).
Blinkers x4.
Mirrors x2.
Tail-light mount. (I have the light itself).
Chrome rear mudguard.
/\ All of these parts have to be in good or better condition.
\/ All of these bits have to be in decent, useable condition (or better).
Bits needed to suit TC100:
Both plastic side covers.
Blinkers x4.
Mirrors x2.
Chrome front mudguard.
Original clutch lever.
Re: TS185 and TC100 bits.
« Reply #1 on: June 01, 2008, 10:00:28 pm »
front guard should be silver on a L model Nathan
 cant find the guys details  but he was selling them as TM125 seat covers . Old fart may be able to remember him  will give him a yell and see.
decals here
The usual WWW: letters before
reproductiondecals.com/default_frameset.html?suz_14b.html~main
090
« Reply #2 on: June 01, 2008, 10:42:51 pm »
The seat covers..are you talking about a qld guy? Might be a guy named Marco if it is. I have his details if it is the guy you are after.PM me if you want his phone no.
Offline gorby
« Reply #3 on: June 02, 2008, 12:42:42 am »
the TC100 front guard has a tubular support bracket,do you have that piece?
and the blinkers,do they screw into the front headlight brackets?
the blinkers are the chrome rounded type,but are the lenses the short type or the longer ones?
may have some for you,will have to dig them out to assess the condition.
is your 185 tail light the round one?
« Reply #4 on: June 02, 2008, 12:43:15 pm »
Thanks Brad.
Gorby, The blinkers do screw into the headlight brackets. Don't know what type they should be - and for the TC, I don't mind if they're not the exact right ones.
I've got the tubular bracket for the TC front guard, but it's a bit bent. I'm pretty sure I can straighten it, but a straight one would be nice too.
TS tail light is round with orange reflectors on the side. Looks identical to a DT250A one (might actually be a DT item?).
Quicksilver
« Reply #5 on: June 02, 2008, 02:07:04 pm »
Nathan.
What year TC100? I have one here less back wheel. Engine seems ok. Tank real nice.
Might be good for parts.
Offline BETRIC
« Reply #6 on: June 02, 2008, 04:28:33 pm »
Nathan 1973 TC100 did not not have blinkers fitted from the factory, only TS100 had them as standard.
DELTEK, 72 MINI TRAIL, 73/4 XR75, 77/78 XR75, DG MONOSHOCK FRAME XR75, REDLINE FRAME XR75, PK RACING MONOSHOCK FRAME XR75, JWRP XR FRAME, SL70K1, 81 CR80RB, TY80A/B, YZ80A/B/D, GT50/80A, GTMX80A, 73 GTMX, GT1, COOPER MX, COOPER ENDURO,MX360A,MX250B,YZ125X MX100, 72 XL250, TC100,TL125, TY250C,IT250J
« Reply #7 on: June 02, 2008, 06:45:41 pm »
Are 3  185 L model blinkers on ebay now . are round with chrome stems.
 They are featured with what looks like some XT250 blinkers. Item number: 190225586934
 Yeah 090, Marco does ring a bell. he makes DG swingarms for xr 75s and lives down near logan village
« Last Edit: June 02, 2008, 06:58:27 pm by pokey »
« Reply #8 on: June 03, 2008, 06:18:41 pm »
I got a 73 TC100 Nathan,, Deal time.....like drop me off a lost somewhere Honda SL125 (Snowy??) and it is yours.... ;) Oh and 73 TC100s did not have indicators as standard, Tim
 Damn mine is a green 74 model!!!!!!!!!!!!!!!1
« Last Edit: June 03, 2008, 06:25:19 pm by Tim754 »
Offline halo1963
« Reply #9 on: June 03, 2008, 07:40:56 pm »
I have a couple of those seat covers from the same guy
I purchased them for a TM250 74/75 but it does not fit
I thought they may fit TM250 72/73 cost $30.00 each
Regards
halo1963
Regards
Halo1963
« Reply #10 on: June 03, 2008, 09:58:12 pm »
yerp Halo thats definately a 185 seat cover he was selling them as TM's
 as for wheels. rear is the same as a TS125 and TM 125 cept the TM is black hub and alloy rim. fronts are different as the 185 has a larger brake hub
Doc
« Reply #11 on: June 05, 2008, 05:20:00 pm »
Nathan go for a TS125er or TS185er (maybe TS100er even) rear wheel. These are a solid mount sprocket and replace the crappy cush drive setups. Unless of course you're resto'ing  ;)
« Reply #12 on: June 05, 2008, 08:06:02 pm »
I'm restoing. :)
Funnily enough, I bought a DT175A wreck the previous weekend, and only go around to unloading it a couple of hours before Jim arrived with the TS.
The DT had an odd rear wheel, which turns out to be the same as the TS185... So if I have to build up a wheel, I can now do it without pulling the original wheel apart.
Doc
« Reply #13 on: June 07, 2008, 08:07:40 pm »
fancy wrecking a perfectly good wheel by fitting it to a yamaha! ;D That TS125R that Quicky posted a link to would be the ducks guts for a resto. Near all there and in quite good unbastardized condition. For $500 buy it now if you spent another $500 you'd have a nice little bike ;D 'all' the TM stuff bolts onto them as well  ;)
