Author Topic: WTD rear shock springs 85 lb/in - 15 N/mm, 270 -290mm long  (Read 954 times)
« on: October 22, 2013, 08:28:06 pm »
Chasing a pair of rear shock springs between 270 and 290mm free length.  In aprox 15.00 N/mm (85 lbs/in).
For those that don't know the spring rates, the aproximate dimensions ...
Wire thickness - 7.5mm
Coil outside diameter - 62mm
Number of active coils - 11 to 12
Let me know the exact dimensions and I'll do the calculations  :-)
Re: WTD rear shock springs 85 lb/in - 15 N/mm, 270 -290mm long
« Reply #1 on: October 22, 2013, 09:19:48 pm »
I buy all my springs new from Cramer, not cheap but you get exactly what you want. It's very hard to find the desired springs second hand.
« Reply #2 on: October 22, 2013, 09:39:53 pm »
Will call you tomorrow morning Walter, thanks  :-)
